Author Topic: NEED: (Pics added) How to change the stock clamps to T-Bolt clamps please?  (Read 26460 times)
Offline KWhale
  • Playing with my
Deep - I did remove the rubber pieces from the tube where Clamp 5 and 6 go.  My problem was a fear of crushing something so I did not tighten them down tight enough.  I put clamp 5 back in place and tightened it as much as I dared (much harder than the first time) then went around and tightened 4,4a and 6 as well.  Seems to be holding after a couple of short but hard drives.
Good, you were supposed to, good job!
I know its not much but since the mod meet I have spent over a grand with Dave :/
Don't stop now, keep on spending, I'm sure they appreciate it.  :)
Good!  Could you order me up some stuff?
Offline IBDRINKEN
  • Donkey Master
maybe soem clamps :)
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
