Author Topic: Help? Anyone with a 2008/2009 wiring diagram?  (Read 2028 times)
« on: June 15, 2010, 12:15:14 PM »
I'm looking for where the signal for the remote door lock receiver signal wire enters the BCM.  I looked at the 2006 wiring diagram and that shows the signal enters the BCM at connector C2, pin 12 (Tan/white wire).  But when I looked in my 2008 GXP, there is no wire at that pin location on C2!  Hmmph!
I want to trace it to see if that signal is usable as an indicator of a locked/alarmed car, so that I can use it to trigger an interior radar motion sensor.  (Plus others may want to use it as an input to the Auto-Window controller I posted about.)
Thanks for any info.
EDIT: This is the diagram I had... but as I said, there is no wire at pin 12 on C2 (on my car)
[ Guests cannot view attachments ] :
« Last Edit: June 15, 2010, 02:04:32 PM by TomatoSoup »
Re: Help? Anyone with a 2008/2009 wiring diagram?
« Reply #1 on: June 16, 2010, 09:27:13 AM »
No-one?  OK I guess I'll have to try the BB  :huh:
« Reply #2 on: June 16, 2010, 09:51:33 AM »
I have the 07 DVD, nothing else!
« Reply #3 on: June 16, 2010, 01:14:41 PM »
This file is different from the one that you posted above. Although I can not verify it's accuracy, my source states that it's from the 2008 model GXP.
« Reply #4 on: June 16, 2010, 02:49:05 PM »
Thanks Bob!
Darn it, though, that shows the receiver is now connected to the GMLan rather than an explicit level output.  Guess I have to ditch that idea.  Bummer.
