Author Topic: Enging light came on.  (Read 2026 times)
« on: July 19, 2010, 11:34:37 PM »
Joe  or who ever knows,Got an engine lite and code P013A says Fuel Air Metering  ?Going to look it up not sure what this means or is.  if you know Chime in Please.
    Bobby    :huh:     :idk:
« Reply #1 on: July 20, 2010, 08:51:00 PM »
Went out this morning and the Engine lite went Out . Does it reset after so many Key turns ?
Offline scanner
Re: Enging light came on.
« Reply #2 on: July 21, 2010, 04:45:05 PM »
Service Engine DTCs are of two basic types.
1. Type A request a light on the first test fail
2. Type B request a light on the second consecutive test fail
The lamp request is typically canceled after three consecutive passing tests.
The DTC is typically retained in history for 50 warm-up cycles with no test failures, or until a clear DTC request is made by a scan tool.
An ignition cycle does not equal a test or a warm-up. Each diagnostic test requires specific criteria to be met before the test runs. If a test runs it will most often result in a Pass or Fail. Both are reported to the on-board diagnostic manager for use in properly operating the engine.
There are several special cases that require a lot of information that would not really help in this case. This is why really talented and professional technicians are paid well. I wish more people appreciated what they do.
www.IATN.net has tons of good information. Good Luck & Clear Skies
Scanner
