Author Topic: LIPSTICK'S 800hp first LNF compound turbo/engine build!  (Read 359853 times)
« Reply #600 on: December 02, 2015, 11:00:53 PM »
Damn, so you are going to uninstall everything and re-install it.
That's a lot of work
Remember, after the coolant issue.....most parts of my manifold was removed to get into the water pump?
Then since my head was lifting we had to remove the head completely to check the head gasket?
The head gasket was definitely damaged, and needs to be replaced.
While the head was out, BTF saw that my valves were different and discovered that SMG screwed me?
Then he saw that two sleeves of my block sunk and the deck needs to be machined?
So basically the whole engine was out due to the above mentioned issues.
It's not like, I'm trying to spend more money and getting all these upgrades for no reason :)
« Reply #601 on: December 03, 2015, 12:25:10 AM »
Wow. This might be the first million dollar Solstice :)
« Reply #602 on: December 03, 2015, 07:59:21 AM »
Yes, after the compound build is done....then converting my SKY into a SOLSTICE....it should probably be the first million dollar solstice ;)
« Reply #603 on: December 03, 2015, 02:08:14 PM »
Would you have to change your forum name to Solstice888 then?
« Reply #604 on: December 03, 2015, 03:43:41 PM »
Maybe! Lol
But it will never happen, since I like my car (sky) better than solstice.
« Reply #605 on: December 03, 2015, 09:19:31 PM »
Solstice888
How far is BTF from you?
« Reply #606 on: December 04, 2015, 08:11:53 AM »
6 hours :(
« Reply #607 on: December 04, 2015, 10:22:25 AM »
He might be closer to me.
I think this coming summer I need to drive up and visit.
RI is not too far from PA
« Reply #608 on: December 04, 2015, 02:44:23 PM »
Most of the KRONUS peeps are in the area. Hopefully my car will be finished this coming summer, so I can hang out with them. They're a good crowd
« Reply #609 on: March 12, 2016, 07:27:38 PM »
New upgraded parts installed:
- zzp Girdled LDK block
- zzp stage 2 cams
- BTF LNF head (full port match & bowl blend)
- gt2860rs turbo
- ARP L19 head studs
Installed and will re-use:
- gt4294r turbo
- Carrillo pro H beam rods
- Wiseco pistons
- Supertech valve springs
- Opel DI injectors
« Reply #610 on: March 12, 2016, 07:45:49 PM »
Disco Potato turbo definitely made the the system way snappier and wakes the Gt4294r up alot faster
At 6200rpm - 52lbs ve flow (40psi)
Too bad at 3800 (35psi), the vibrant vanjen clamp broke today! :(
 I believe time to upgrade to Wiggins Clamp!
« Last Edit: March 12, 2016, 08:38:47 PM by SKY888 »
« Reply #611 on: March 12, 2016, 08:19:03 PM »
WhooHoo
This project is moving forward again.
SaaaaWeeeet
Keep the updates the coming.
« Reply #612 on: March 12, 2016, 08:39:45 PM »
Ha! Yup!
Hopefully only minor things such as clamps will be the speed bumps this time around :)
« Reply #613 on: March 12, 2016, 09:11:35 PM »
Did I just read disco potato?
« Reply #614 on: March 12, 2016, 09:31:17 PM »
GT2860rs aka disco potato
« Reply #615 on: March 12, 2016, 11:52:28 PM »
I'm not savvy. Can you explain?
« Reply #616 on: March 13, 2016, 12:21:51 AM »
Long long time ago......Garrett turbo company developed a turbo for this project car called "disco potato" that has an sr20 engine.
Although it only made 280whp, the  car was very responsive. Spool was almost non existent.
The turbo used in this vehicle is the gt2860rs also become popularly known as disco potato
For more detailed and accurate story ......
http://www.superstreetonline.com/how-to/project-car/0306scc-project-nissan-silvia-part-2/
« Reply #617 on: March 13, 2016, 01:29:08 AM »
Wouldn't t-bolt clamps be more robust?
« Reply #618 on: March 13, 2016, 07:16:04 AM »
No bob, using t-bolt clamps usually means using a silicone to attach a charge pipe to an intercooler's end. Sometimes this t-bolt will slip, or the silicone rips.
I'm using Vibrant vanjen clamps that locks up two aluminum assemblies together.
It has o-rings to keep it fully sealed as well.
But I wish I used Wiggins brand, which is the best of the best, it's about $300 a set those.
I needed 3 sets for my application tho.
Anywho, you can see here where I used the vanjen clamps
« Reply #619 on: March 13, 2016, 10:36:01 AM »
For GJ
Quote from: superstreetonline
Several Garret executives also experienced the Potato. They were so impressed, they decided to produce the turbo, double the engineering staff in the aftermarket department, and start applying this modern Garrett technology to a whole range of aftermarket turbos. Technically, this is a GT28R with a 62 trim compressor (.60 A/R) and a 76 trim turbine (.86 A/R), but you don't need to know that. Ask anyone at Garrett for a Disco Potato turbo, and this is what you'll get.
« Reply #620 on: March 13, 2016, 12:03:08 PM »
I think I want a disco potato for my TV. Sound like a nice upgrade!
Offline Jim
« Reply #621 on: March 13, 2016, 10:58:02 PM »
Here ya go.....
« Reply #622 on: July 30, 2016, 09:44:19 AM »
Any Updates?
« Reply #623 on: July 30, 2016, 06:11:43 PM »
He hasn't been on here since March. Yeah, I wonder what happened to the build...    :idk:
« Reply #624 on: September 17, 2016, 09:42:06 PM »
after more than 5 years of waiting.....LIPSTICK is back!!! :)
https://youtu.be/BE7EmGrliw8
