Author Topic: battery removal video  (Read 6141 times)
« on: August 25, 2010, 08:18:13 PM »
Re: battery removal video
« Reply #1 on: August 25, 2010, 08:55:36 PM »
A couple of notes to add.   There is some things wrong with that video
The so called washers on top were panel anchor nuts and do not go on top of the fender, they belong on the black frame so don't remove them.  If the fall off, stick them back on and bend the spring tab into the hole to get them to remain on.
The bolt behind the door doesn't need any special tools other than a 12" extension with a 10mm socket to remove/install it.
The black frame is what align and holds the fender in place.  It has 3 10mm bolts that hold it on and it is critical that this frame get re-installed in the exact same location so you should use a black magic marker to trace around the frame on the bolts closest to the door and a gray magic marker to mark on the front one he left on as a pivot.   All 3 bolts have oblong holes for alignment adjustments that are made at the factory.  Using the marker saves you a ton of headaches when reassembly.
Also his wheel well liner was already removed, there are 4 or 5 7mm bolts that hold that on to the fender.
« Reply #2 on: August 25, 2010, 09:18:47 PM »
Ah.  Oh, well.  Seemed good.
« Reply #3 on: August 25, 2010, 11:52:59 PM »
gee DBG, have you done that a few times?  I am betting you wrote that from memory...
you should write a book.  I would like to be featured in Chapter 16.  Thank you.
« Reply #4 on: August 26, 2010, 03:03:00 AM »
didn t watch the vid, coz DBG made a few remarks.
i was wondering, do we have a DIY for changing battery?
i will be needing that soon, and i want to do it by myself..
« Reply #5 on: August 26, 2010, 09:21:31 AM »
He would need pink pages!!
« Reply #6 on: August 26, 2010, 09:56:37 AM »
Yes, from memory.  If you want, I'll do a correct video from my wife's stock coupe.  I'd do it from mine but I have side skirts.
« Reply #7 on: August 26, 2010, 09:57:36 AM »
And he doesn't want GJ looking up his skirts!!
« Reply #8 on: August 26, 2010, 10:15:44 AM »
thx DBG!!!
« Reply #9 on: August 27, 2010, 09:23:25 AM »
Watched the vid and printed this out.  A forum dedicated just to Kappa videos would be nice.
« Reply #10 on: August 27, 2010, 10:40:00 AM »
Kappa-tube coming right up!
