Author Topic: Open your hood and take a picture of your engine bay  (Read 36155 times)
Re: Open your hood and take a picture of your engine bay
« Reply #25 on: September 27, 2010, 08:22:10 AM »
the fit is perfect, and they will never fall off.
I go to carshows a lot, and that's the reason why I got a set.
The MRZ caps are expensive.....but they are good quality.
« Reply #26 on: September 27, 2010, 01:21:48 PM »
For those who have installed the MRZ caps what is your thoughts on these for fit and function. Any chance of these coming loose and falling off, and would you do over again ?
They won't fall off, but I wouldn't do blue, the second set is fading.  I'm really disappointed.
Offline jlab8
« Reply #27 on: September 27, 2010, 01:59:44 PM »
What happened to your covers? Did you take them off to help get rid of heat?
I don't like the way they look. I'd remove the cover over the intake manifold, too, but I don't feel like taking off the fuel rail to get it out yet.
« Reply #28 on: September 27, 2010, 02:04:50 PM »
Agreed. That's a humdinger of a red funnel!   :poke:
:lol: I was thinking the same thing. "The red funnel really sets everything off!" :lol:
Offline jws0318
« Reply #29 on: September 27, 2010, 04:32:36 PM »
I agree - they fit fine, but i have a red set and 2 of the caps are very faded.  Very dissappointing considering the price.
Offline reedred
  • Turgid
« Reply #30 on: September 27, 2010, 09:21:27 PM »
I would participate, but Joe's already yelled at me for posting dirty pictures.
« Reply #31 on: September 27, 2010, 11:06:23 PM »
Oh come on reedred, we won't tell Joe. What ya' got under that hood on the Sky.
Offline nighttripper
2007 Saturn Sky; Midnight Blue; 2.4L; DDM Header/High Flow Cat;DDM Stage III S/C; Kenwood Stereo/Nav; FK- LX 10 Rims; Yokohama A/E Tires; Solo Mach/Resonator C/B Exhaust Quad Tipped; DDM Probeam/Backbone/Catch Can; DDM Cam/Coil Cover/Center Consol/JPM covered; Center feed fuel, PLX guages, A pillar, Stage 3 clutch fly wheel
« Reply #34 on: September 29, 2010, 03:31:08 PM »
The MRZ caps are great.  I have received many compliments on them and they really add some life to the engine compartment!  We had the Red ones installed and they look and fit as good today as when they were installed years ago.  No fade, they fit perfect, and I and Carol believe they are a great addition to the Engine Bay!
Offline DragonSolGXP
« Reply #35 on: September 29, 2010, 03:45:54 PM »
This is only a small section
« Last Edit: September 29, 2010, 03:52:58 PM by DragonSolGXP »
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #36 on: September 29, 2010, 03:48:21 PM »
Under our Formula Hood style for the CAI. Thanks Norm
« Last Edit: September 29, 2010, 08:11:38 PM by normsf »
Offline RobertAshby
  • American Grunt
« Reply #37 on: June 23, 2014, 06:33:17 PM »
Upgraded to 480 hp LS3 with T56
2007 Cool, 480hp V8 t-56, dual 3in ss exhaust, ac, Racelogic TC, LSD, Wilwoods, Probeam, Werks frame stiffener/backbone, BC coil over shocks,  Recaro Speed seats,  Werks roll bar
« Reply #38 on: June 23, 2014, 06:39:20 PM »
Holie Zombie
Offline PyrateDave
« Reply #39 on: June 23, 2014, 08:42:37 PM »
Ok, I am liking the air filter built into the hood, quite ingenious...
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #40 on: June 24, 2014, 12:44:59 AM »
Hello, thankyou very much. Heres a few more.
« Last Edit: June 24, 2014, 12:49:19 AM by normsf »
Offline Robotech
« Reply #41 on: September 29, 2014, 03:00:52 PM »
Day:
Night:
« Reply #42 on: September 29, 2014, 04:46:15 PM »
I'd love to put LED lights in the engine bay but haven't yet found a way. Don't have the plastic engine cover any longer and don't particularly want to look at them in the day light.
Yours looks good RoboTech.
Offline jlettiere
« Reply #43 on: September 30, 2014, 09:17:32 AM »
RoboTech,
Where did you get the engine cover? Looks great!
« Reply #44 on: September 30, 2014, 06:42:13 PM »
very nice
« Reply #45 on: October 01, 2014, 09:53:14 AM »
I'm liking it Robotech!!!
Offline Robotech
« Reply #46 on: October 01, 2014, 05:09:05 PM »
Thanks guys for all the compliments.
Thanks! I'd just look for anywhere you might be able to tuck them underneath something. Or maybe run them on the inside of the frame rails. I was thinking about what I'll do with these once I go with a Turbo as the engine cover will have to go and I will figure something out.
One note. I attached the LEDs to the underside of the cover using blue (it is almost clear) High Temp RTV gasket maker.  While they came with an adhesive backing, I didn't trust it to stand up to the heat.  The LEDs are waterproof and their coating looks like they should stand up to these temps fine but the adhesive not so much. If putting LEDs anywhere in the engine bay, I'd recommend doing something similar.
One thing you may consider is getting a custom cut "engine cover" made out of 2-3mm carbon fiber. You can find sheets of it on ebay for about $100 and for another $70 or so they'll cut out a pattern with a CAD Drawing you provide (if you know Illustrator you can save an Illustrator file in CAD format).  Just design and modify it so you can attach it to your stock engine cover stands and then put your LEDs under that. That's probably what I'll wind up going with.
Quote from:  jlettiere
RoboTech,
Funny story behind that. See, this isn't my first Sky. I had Sky number 1108 off the assembly line back in 2006 and owned her for about a year. It was Midnight Blue, 2.4 NA, black leather interior.  I adored that car.  I wound up having to sell her after having her for a year because she inadvertanly became my only reliable car and that didn't work for me. I vowed though that one day I would have another one. It just so happened that I had wanted to take the 2.4 engine cover off and have it painted by a coworker.  Problem was, I sold it before he got the cover finished.  He got the paint laid down but still needed to do some touch up work and clear coat it.  Since the car was sold, he let it sit unfinished.
Fast forward to today and now I have a 2007 Sky, Midnight Blue, 2.4 NA, with black leather interior. Except for the wing on the back and the billet grills up front, it was identical to my first Sky. I thought of this project some time ago and decided to ask my coworker if he still happened to have that old engine cover I gave him. He looked at his parents' house where he had been staying at the time and found it...still unfinished. He gave it to me, I touched up the spots that needed it except one (You can see where the silver got flaked off just above where the power steering cap is in the second picture...left it that way as a reminder and a bit of character), weathered it a little with some old military model techniques I know, and clear coated it. Then I wired up the LEDs and put in a switch that is triggered by the hood.  Hood down, lights off. Hood up, lights on. Real simple setup.
« Last Edit: October 01, 2014, 05:23:09 PM by Robotech »
Offline Hoosier GXP
  • Hoosier GXP
« Reply #47 on: October 01, 2014, 08:42:16 PM »
I just can't make up my mind  :huh:
This.....................
or this....................
or this...........................
or one of several others I can have :idk:  :idk:  :idk:
« Last Edit: October 01, 2014, 08:57:08 PM by Hoosier GXP »
Offline Jim
« Reply #48 on: October 04, 2014, 12:46:43 PM »
The carbon fiber look is nice. Are they all hydro-graphics?
Offline Hoosier GXP
  • Hoosier GXP
« Reply #49 on: October 04, 2014, 07:51:35 PM »
The first one is powder coated. The rest are dipped
