Author Topic: How to: Manual Transmission and Limited Slip Differential Oil Change  (Read 37537 times)
Offline Imaj
Re: Royal Purple for Transmission and Differential
« Reply #25 on: October 28, 2010, 09:51:54 AM »
Good luck Helios. Feel free to take pictures since I will be changing my trans fluid this weekend. :)
Offline 1KULSOL
« Reply #26 on: October 28, 2010, 09:53:33 AM »
Going to change out the transmission fluid today to Royal Purple. Hopefully it'll smooth out the shifting.
I changed mine out to RP and I did not notice any difference ... but hoprfully you will get better results.
« Reply #27 on: October 28, 2010, 01:02:41 PM »
I just dropped mine off at the local Chevy dealer and let them do it. Hopefully my car will come out unscathed.
I hope so. It's an expensive investment for it to not be effective. I'll end up changing out my differential fluid on my own when I get back to my house after I finish working in GA.
« Reply #28 on: October 28, 2010, 09:13:15 PM »
Picked up my car after fluid change. There was SOME difference, but not much. It did not solve my difficulty with shifting into 3rd and 4th gears though. Bummer... :'(
« Reply #29 on: November 01, 2010, 10:55:57 AM »
That sucks! Hope you get it figured out.
Offline old goat
« Reply #30 on: November 01, 2010, 11:01:30 AM »
 Do you have the stock shifter or a JPM? After I swapped to the JPM shifting was much harder until I switched to a weighted ball, the stock shifter is weighted the JPM is not, works much better with the weighted ball from JPM), my shift knob weighs almost a pound and a half.
« Reply #31 on: November 01, 2010, 11:48:38 AM »
I know mine does! :D
« Reply #32 on: November 01, 2010, 12:29:57 PM »
Yes, I have the JPM shifter. I did not know JPM had a weighted ball. Do you mean the aluminum ones? I'll look into it. Now, that you mention it, I didn't experience shift problems until after I got rid of the stock one.
Offline old goat
« Reply #33 on: November 01, 2010, 01:17:23 PM »
Stainless Steel baby, a pound and a half aluminium shifter would be the size of a basket ball. I was the first to use the weighted ball for exactly the problem you describe. This is a very common problem on the Subaru, the same vendor that makes the shift knobs for JPM makes the weighted ones for the Subaru. We use a Subaru thread on the JPM shifter. He does some different colors and shapes.
Here is the thread from back in August of 09
http://www.kappaperformance.com/forum/index.php?topic=2657.0
« Reply #34 on: November 01, 2010, 02:13:32 PM »
Thanks for the heads up, OG! Just spoke with Joe and he's working on getting me the Gunmetal Blueish/Gray Flamed.
« Reply #35 on: November 01, 2010, 02:15:46 PM »
:yay: You will love it, Joey! :yay:
Offline old goat
« Reply #36 on: November 01, 2010, 03:12:01 PM »
Did you ask about the pound and a half aluminium one?  :lol:
It was only an accident, I figured this out been very happy with mine. I wondered when I pulled the stock one why it was so heavy, then I figured it out. It does get very cold in winter, but that's what gloves are for.
Offline Imaj
« Reply #37 on: November 01, 2010, 03:46:27 PM »
Would the cue ball looking ball have the same weight?
« Reply #38 on: November 01, 2010, 09:12:11 PM »
Figured the aluminum one could have been weighted with a lead center, kind of like how golf clubs can have adjustable weights installed on the club head.
Offline old goat
« Reply #39 on: November 02, 2010, 06:58:08 AM »
 I believe the cue ball is slightly less, not significant. I think I am the only one who has used the one with the collar, JPM made me a custom boot for it.
« Reply #40 on: November 02, 2010, 09:24:18 AM »
I thought mine had a collar, but I could be wrong. :idk:
I know mine has an extension. :D
Offline old goat
« Reply #41 on: November 02, 2010, 09:29:40 AM »
Yours the collar is a seperate piece, mine it is part of the knob, requires a different shift boot. With the seperate collar you can adjust the height, on mine you can not.
« Reply #42 on: November 02, 2010, 09:36:46 AM »
Got it, thanks.
« Reply #43 on: June 15, 2011, 08:46:25 AM »
Kelu, can you give me any links for the Motul you used for diff and tranny?
October will be my 4th annual service and i am thinking of changing the diff and tranny fluid.
did you have to put any additives?
thx
« Reply #44 on: June 15, 2011, 09:06:35 AM »
http://www.kappaperformance.com/forum/index.php/topic,2611.msg31144.html#msg31144
Motul 90PA for differential (a 2L bottle is enough)
http://www.motul.com/ro/en/products/58?f[application]=141&f[range]=25
Motul Gear 300 75W90 for gear box (i don't remember exactly how much you need, check the manual)
http://www.motul.com/ro/en/products/106?f[application]=141&f[range]=25
P.S. Next time use search first :P
« Reply #45 on: June 15, 2011, 09:25:14 AM »
Thx!
