Author Topic: 2.4L Air Intake Resonator Removal (Mallet Mod)  (Read 3992 times)
« on: November 28, 2010, 04:42:29 PM »
I recently decided to remove my Air Intake Resonator for another modification and thought I would document this simple process:
Tools needed: Torx size 30, Phillips (cross) screwdriver, Rubber Mallet, Hacksaw (or a really sharp knife)
First of all I cut the mallet head off by splitting it across the top at the handle to make two "hockey pucks".  I then rinsed the mallet with water to remove any debris. This makes two pieces about three incles in diameter and four inches in length.
[attachment=1]
[attachment=4]
I then removed the two Torx bolts on the frame and loosen the hose clamp with the Phillips screwdriver. Removal is easy, just lift up and out towards the driver side.
[attachment=2]
Now insert the Mallet head into the hole left by the missing resonator and remove, and cut to fit. My final dimensions were one and a half inches in thickness and two and a half inches in diameter at the clamp. That means I trimmed about an inch off both sides of the mallet head to make it fit perfectly and tight in the hole and not restrict airflow.
[attachment=3]
Rinsing the mallet with water again to remove any debris. I then tighten the hose clamp is as tight as it would turn.  This mallet plug all that is keeping out the unfiltered air out of your engine.
[attachment=5]
This removal frees up a lot of engine compartment space, does not make any more noise than stock, and has not negatively impacted my fuel economy.
« Last Edit: November 30, 2010, 11:05:40 AM by CT_Solstice »
(UPDATED) 2.4L Air Intake Resonator Removal (Mallet Mod)
« Reply #1 on: November 30, 2010, 11:07:44 AM »
Updated the pictures and added more data for the installation.  :thumbs:
Offline Hal 9000
    • Kappa Krap
Re: 2.4L Air Intake Resonator Removal (Mallet Mod)
« Reply #2 on: November 30, 2010, 02:36:33 PM »
I just did this myself last weekend.
I used a plastic black cap from a spray paint can, cut down to about half height instead of a mallet.
Offline ophidia31
« Reply #3 on: June 15, 2011, 08:53:32 PM »
Did this about a week and half ago. Used a hockey puck and cut it to size with my dremel. Looks alot better than the giant resonator sitting there. Though there isnt a big sound difference normally, but some rare occurances of some slow speed crawling (less than 10mph) it drones like a mofo. Im guessing that is what the resonator was for. lol
2013 Grigio Abarth 500
« Reply #4 on: June 15, 2011, 11:15:58 PM »
Not too sure about the extreme low speed sound... I just don't drive tha slow! LOL!
Offline ophidia31
« Reply #5 on: June 16, 2011, 06:49:53 PM »
I mainly notice it when I visit my mother and have to turn around in her driveway to get back out because Id scrape if I back out. Doesnt make sense because I dont scrape when going into the driveway.  :idk:
