Author Topic: Flywheels  (Read 11309 times)
Re: Flywheels
« Reply #25 on: December 24, 2010, 12:55:35 AM »
let me ask this, would you repalce both at the same time, and just out of curiousty how much was the flywheek, couldnt find prices on their site.
Offline Kuprito
Solo + Magnaflow 3" exhaust
OZ Ultraleggera 19"
Rotora 4p front
Brembo 4p rear
LV Brace
Custom Backbone (1/2")
Re: Flywheels
« Reply #27 on: December 24, 2010, 10:04:49 AM »
The cost question was answered for the Fidanza. That is the normal e-bay price, but list is about $500. Spec prices are on Spec's web site as well as some of the sites of our supporting vendors. Clutch prices on on Spec's site and vendor sites, also.
As for replacing both at the same time - ABSOLUTELY. Clutches and pressure plates should always be "paired" as not doing so is almost a guarantee for trouble. Also, the labor on a Kappa LNF is 9 hours, so doing THAT job twice would be painful, financially AND physically !!!!!!!!!!!!!
Offline melissadunagan
Re: Flywheels
« Reply #28 on: December 24, 2010, 02:27:49 PM »
  How is the clutch and flywheel different on the 2. L and the 2.4 L engines? and what kind of clutch and flywheel would ya'll recommend far the 2.4 L engine?
             Thanks
Ferret Lady
Re: Flywheels
« Reply #29 on: December 24, 2010, 02:32:23 PM »
             Thanks
Most importantly, the bolt pattern. For a stock 2.4 nothing "stronger" may be necessary. It has been "leaned on" or has either type of forced induction systems installed, a Spec light flywheel and 3+ clutch (or equivalent) would be good. Check with our supporting vendors after the holidays.
Re: Flywheels
« Reply #30 on: December 24, 2010, 03:20:40 PM »
I love ebay but something like that I would buy direct from the supplier since if you have any problems with said item. Correct me if Im wrong.
Re: Flywheels
« Reply #31 on: December 24, 2010, 04:22:03 PM »
Agreed, but UltraRev is a really store with a phone number and everything!!
Re: Flywheels
« Reply #32 on: December 24, 2010, 11:33:40 PM »
ddm and werks, sell spec clutches
or just buy directly from SPEC
Re: Flywheels
« Reply #33 on: December 24, 2010, 11:42:02 PM »
HEY!!!!!!!!!!!! DDM is a supporting vendor, right? Give THEM the money. You can bet that Dave and his crew WILL support YOU. And if you whine, he might cut a bit of a break.
Re: Flywheels
« Reply #34 on: December 25, 2010, 02:59:40 AM »
DDM is awesome!!!   Even if you don't whine.............DDM will give you the support you want/need  :)
Re: Flywheels
« Reply #35 on: December 25, 2010, 08:30:05 AM »
The Spec was not a choice of one Solstice 2.4 owner on the big forum. Or maybe it was the a sensitive owner.
I'll be going with Execdy clutch for around $300 and Excedy aluminum flywheel for about the same from ebay. I don't need uber holding power but the stock clutch on the 2.4 is having a hard time holding double the stock power.
The 2.4 selection of clutch parts is very good since Cobalt, Ion, and HHR.
Re: Flywheels
« Reply #36 on: December 25, 2010, 10:03:03 AM »
The 2.4 does have a lot more choices. Just make absolutely sure that the EXACT flywheel (the p/n) is the correct application for the REAR WHEEL DRIVE 2.4. Sometimes there are differences. Example: the flywheels for the FWD and RWD LNFs are different.
Jebsmith
Re: Flywheels
« Reply #37 on: December 25, 2010, 10:16:13 AM »
Spec 3+ with spec flywheel here.  I also have the non sac, purchased directly from spec with military discount for 900 dollars (no sponsors) Took me 22 hours from start to finish.  I have never changed a clutch before and will gladly pay 1k $ next time.
