Author Topic: Your thoughts and opions on a possible turbo system for my Sol.  (Read 25959 times)
Offline Houstice
« on: December 23, 2010, 07:14:37 AM »
I am seriously considering installing a Turbocharged or Supercharged system in my 2009 Solstice Street Edition. I have read many different threads on the Solstice and Kappa Forum sites to get an idea who may have the best solution. I have also been talking to a performance garage here in Houston as to what their suggestion would be. We have looked at the different sites(ie. DDM,Hahn,and Performance Werks).
This Performance garage came up with the following proposal.
I would be grateful for your input and comments.
Thanks!!
Below is a rough proposal of what he would do:
Parts:
1. Intercooling piping custom made similar to Hahn or DDM.
2. Bar and plate intercooler
3. 304 Stainless Steel Turbo Manifold
4. 304 Stainless Steel Downpipe with O2 sensor provisions
5. Garret GT Turbo ( 2860 series )
6. Tial MVS Wastegate
7. Tial Q BOV
8. 3" Turbo Intake with dryflow filter (custom)
9. Fulltune(Dyno) of turbo system with HP Tuners
10. Stainless steel braided oil plumbing lines
11. Upgraded fuel injectors for turbo system
12. Return fuel system conversion w/ AFPR
13. Walbro 255 lph high pressure fuel pump
14. Heatshielding for turbo system
15. T Bolts and 4 ply silicon couplers for intercooler system
16. Spec 2 or 2+ upgraded clutch, maybe 3+
17. Aluminum heavy duty radiator for turbo system
At the sametime I will be installing the Solo Performance SQR2 exhaust system and a high flow cat.
« Last Edit: December 23, 2010, 09:48:26 PM by Houstice »
Re: Your thoughts and opions on a possible turbo system for my Sol.
« Reply #1 on: December 23, 2010, 07:19:16 AM »
First of all 2009 Solstice Street Edition means 2.4L NA (LE5) or 2.0T (LNF)?
« Reply #2 on: December 23, 2010, 07:21:15 AM »
very good parts bro.
I suggest using 321 stainless steel for your manifold and downpipe.   304, is ok, and a cheaper product.  Yes, 321 stainless steel is a bit pricey, but the best thing there is especially for your manifold.
You don't want something that will be customized for your car and paying that person high $$$$ then later on, cracking.   Then you'll have it repaired/built again.
321 stainless steel tubing is one of the most desirable materials for exhaust systems because of its excellent resistance to fatigue and cracking at elevated temperatures. It is usually the material of choice for high temperature turbo applications.
I am not sure if you've heard of "cryo-treatment".  You can go to my sponsor's website nitrofreeze.com   to learn more
You can have your 321 ss manifold cyro-treated as well for durability.   321 stainless steel is 17-19% carbon. It would benefit from cryo-treatment. the manifold will undergo stress relieving. This helps remove stresses that will develop intro cracks as the part ages. Retained austenite will convert to martensite making the manifold less susceptible to cracking.
Might as well just pay one time! :)
« Last Edit: December 27, 2010, 10:00:02 AM by DeepBlueGXP, Reason: non supporting vendor »
Offline Houstice
« Reply #3 on: December 23, 2010, 07:25:26 AM »
It's a 2.4L engine.
Offline Houstice
« Reply #4 on: December 23, 2010, 07:30:26 AM »
I am not sure if you've heard of "cryo-treatment".  You can go to my sponsor's website: nitrofreeze.com   to learn more
Thanks a lot!! I will relay this to him after the holidays.
« Last Edit: December 27, 2010, 10:00:50 AM by DeepBlueGXP, Reason: non supporting vendor link removed »
« Reply #5 on: December 23, 2010, 07:31:24 AM »
then once all your custom "hot parts" are fitted perfectly, you can have them swaintech coated.   This will keep heat inside the pipes which will help a bit with spooling due to thermal velocity.
Plus of course swaintech coating will help your engine bay temp cooler......  :)
« Reply #6 on: December 23, 2010, 07:35:31 AM »
It's a 2.4L engine.
Not too familiar with 2.4L engine but your list looks good. The only thing which I can comment is about the turbo, I wouldn't go GT25 being too small in my opinion. I would go GT28 to aim over 300hp.
« Reply #7 on: December 23, 2010, 07:36:02 AM »
by the way, let me know if you are interested in getting 321 ss for your custom parts.
I can refer you to my sponsor contact from burnsstainless
damn, I sound like a salesman....lol
« Last Edit: December 23, 2010, 09:17:29 AM by DeepBlueGXP, Reason: removed non vendor link »
« Reply #8 on: December 23, 2010, 07:37:03 AM »
I agree with my buddy! :)
GT2860 - for the quickest spool
or for more power up top....  GT2871
« Reply #9 on: December 23, 2010, 07:44:25 AM »
hey, what's wrong with salesmen?? we are good guys if you get to know us out of the office environment... :lol:
good luck Houstice!
aren't you adding an exhaust to your mod?
Offline Houstice
« Reply #10 on: December 23, 2010, 07:47:05 AM »
I plan on installing the Soloperformance SQR2 or 2.4 mach w/ resonator.
« Reply #11 on: December 23, 2010, 07:47:36 AM »
Arabas, he already mentioned
At the sametime I will be installing the Solo Performce SQR2 exhaust system and a high flow cat.
« Reply #12 on: December 23, 2010, 07:47:49 AM »
Haha!  my dad used to own a used car dealership!  I grew up with salesman.....I know how it goes!  lol
« Reply #13 on: December 23, 2010, 07:57:03 AM »
Kelu, the exhaust was probably added later by Houstice.
Houstice, how come you don't go with the DDM S/C?
Offline Houstice
« Reply #14 on: December 23, 2010, 08:08:23 AM »
Thanks,
I haven't rulled out DDM  and I have talked them about their systems. This thread is for me to get an idea about putting a turbo system(this proposal) in my car as compared to a supercharger system. And as I will be spending a large amount of money on this, I want to be sure and happy of my choice.
Quote from: Arabas .link=topic=5854.msg81512#msg81512 date=1293105423
« Reply #15 on: December 23, 2010, 08:15:43 AM »
by the way, if you can get SPEC stage 3+,  go with that.
my issues with stage 2 and 2+ are:
- you have not enough cushion, especially if later on, you want to boost higher.  Their tq capabilities are not really that high.
- streebality and driveability is not up to par compared to stage 3+
Stage 3+  = flagship of Spec since it is very streetable/driveable and can handle tons of tq.    Actually, with LNF application, I know that Stage 3+ has more TQ capacity compared to Stage 4!!! :)
I will not go with "stage 4 or 5" due to the fact that they're already 4 or 6 puck which makes them hard to drive on the streets.   Stage 3+ is still full-faced.
« Reply #16 on: December 23, 2010, 08:35:47 AM »
good thinking!!!!
« Reply #17 on: December 23, 2010, 09:35:00 AM »
The clutch is good to around 280 ft lbs depending on how you drive which is well within the comfort zone of the SC. If your going turbo you'll need a clutch like SKY888 mentions.
I didn't see boost controller on your list. I used AEM Tru Boost that fits in a boost gauge location.
« Reply #18 on: December 24, 2010, 01:46:12 AM »
Have you asked the other 2 supporting vendors for a similar proposal?.
Jebsmith
« Reply #19 on: December 24, 2010, 02:55:55 AM »
Could you mention you sponsors again?  I forgot who they are.
Offline Houstice
« Reply #20 on: December 24, 2010, 07:01:55 AM »
Yes, I have talked to Mike at DDM extensively about my car and what they could do for me. I was quite impressed and as I have stated in this thread, I am considering DDM as well.
Offline Houstice
« Reply #21 on: December 25, 2010, 10:48:06 AM »
Thanks NormSky!!
I talked to him and he suggested that it would be set at around 8 psi or so.  I could get used to the new setup and that I could also adjust it afterwards to my needs.
Does that make any sense?
Offline Houstice
« Reply #22 on: December 25, 2010, 11:03:22 AM »
I don't have any sponsors.
« Reply #23 on: December 26, 2010, 05:08:13 PM »
I don't either, but for those that do, it is certainly good to have the data points about what may be working. I know if somebody gave me something for my car and it didn't work as represented then that item would sure come back off to be returned !!!!!!!!!!! Hey, sometimes FREE sucks. Sometimes FREE works out real well. It is good to know either way.
Offline spider
« Reply #24 on: December 26, 2010, 11:45:54 PM »
How strong are the internals of a 2.4
