Author Topic: WERKSracing Kappa/LSx V8 Conversion DIY Installation kit official release!!!!!  (Read 42394 times)
Offline hammy221
but from what i understand the diff alwas has 3 points of connection on both TQ arm and non TQ arm models. the non havein a mount bolted in place of the TQ are mount. i find it hard to belive that the diff would only be supported VIA 2 bolts in the back
so i take it going to a V-8 with a T%^ ill lose that and need to get the non TQ arm diff mount the put where the TQ arm goes now?
Yes that is correct.  If you have a torque arm car you will have to get the aluminum diff. mount, bushing, bolts, support, etc... to mount the front of it to the chassis as they did before the torque arm went into production.
That is correct and not correct at the same time I guess.  With a torque arm setup it is supported to the transmission via the long torque arm, without the torque arm it is supported to the chassis via a large single bushing mount to the upper right front of the diff. case.  While both of these setups work, the torque arm does put more stress on the 2 rearward mounts as they now have to hold the entire rearward weight of the diff., driveshaft and torque arm.  We have seen a few ripped or fatigued rear diff mounts because of this, mainly on cars that have been pushed somewhat hard.
« Last Edit: April 16, 2012, 01:48:48 AM by werks »
Offline hammy221
That is correct, with a torque arm setup it is supported to the transmission via the long torque arm, without the torque arm it is supported to the chassis via a large single bushing mount to the upper right front of the diff. case.
thank you for your input. is there a way to use a TQ arm still like a custom one or is it really not Needed
Offline Anthony H
Has anyone used the DIY kit yet?
What position is the engine in compared to other V8 swaps?  I'd like it to be as low and far back as possible, and I know that some of the V8 swaps can be +/- 2 or 3 inches.
2007 Sky Redline.  GMPP Stage 2 tune.  K&N Typhoon.  DDM Backbone.  DDM Probeam. SOLO Ultra High Flow Cat.  SOLO Mach Shorty.  WERKS Racing Adjustable Rear Sway Bar.
Our kit puts the engine in as low and as far back as we can get it without hacking up the frame rails or cutting and moving the engine mount pads while locating the shifter exactly in the center of the shift lever hole.
« Last Edit: December 20, 2013, 04:49:51 PM by werks »
Offline Anthony H
Thanks for the quick reply, Dave. I didn't want to bother you with another email.  :)
-Anthony
