Author Topic: Have ya' painted or powdercoated the turbo heat shield?  (Read 8120 times)
« on: February 01, 2011, 12:27:50 AM »
Has anyone painted or powdercoated the turbo heat shield? How's it holding up?
My powdercoater has said that he can powdercoat it but we aren't sure how hot it gets. I know we don't need a ceramic coating but we might need a hi temperature powder coat if it gets above about 400 degrees F.
What did you use?
Offline IBDRINKEN
  • Donkey Master
Re: Have ya' painted or powdercoated the turbo heat shield?
« Reply #1 on: February 01, 2011, 12:53:28 AM »
I was thinking the same thing as I wanted DDM to do mine.
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #2 on: February 01, 2011, 07:17:10 AM »
Bob, try 1800 degrees...  I now have a polishing setup on the drill press.  you can use it at the meet to make your stock turbo cover look like a mirror.
Jebsmith
« Reply #3 on: February 01, 2011, 07:41:10 AM »
Black header paint will work.  Or any color header paint from an auto parts store.  I think I might throw some black on mine today.
« Reply #4 on: February 01, 2011, 08:11:02 AM »
Joe, I know it gets hot at the turbo but there's an air space between the turbo and the shield and if the shield was 1800 degrees it wouldn't stay shiny but would turn blue.
Heck, maybe I'll try the hi temp powder. If it doesn't work, the most it cost me is $10 to try it.
« Reply #5 on: February 01, 2011, 09:09:14 AM »
I did mine, Deedle, Go-n Def and Darkteck and it's still looks great.  Not exaclty a mirror finish but the shield is double walled and it doesn't tarnish.  I'm not sure what the material of it is.
$10 isn't bad until it doesn't hold up in the heat and you have to remove it.  Hope it works out.
Most of the google searches show that the temps of the turbo itself get to about 1500 degrees and EGT after the turbo get to about 1350 degrees.  Make sure the high temp powdercoating is rated high enough or you'll be removing burnt paint.
« Reply #6 on: February 01, 2011, 09:18:21 AM »
Removing the powder coating isn't an issue as he has a dip tank that takes it right off. That's got to be wonderful stuff...   :nuts:
I'm an adventurous sort o' guy. Someone has to be first to try it.   :D
« Reply #7 on: February 01, 2011, 09:22:08 AM »
I seem to remember a guy from Texas did his red and it didn't last long.
« Reply #8 on: February 01, 2011, 09:38:49 AM »
I certainly won't be using regular powdercoating. Mine will last until the spring at least.  :lol:
« Reply #9 on: February 01, 2011, 09:56:37 AM »
Look forward to seeing it in May!
« Reply #10 on: February 01, 2011, 10:31:16 AM »
I guess I would be more concerned with the potential to start a fire in the engine compartment and the collateral damage it may cause.  Could end up costing much more then $10.
Offline tazzman
  • with new paint
« Reply #11 on: February 01, 2011, 12:05:31 PM »
Used 1400 dg, peeled off after a few months. Sand blasted it primed it and painted it.
bought one polished. All is well now.
King Penn, W.R.
ASAP Fuse box cover
ASAP Fog light cover
ASAP BU light cover
Debaged
Shorty antenna
Magnaflow catback 3''
New Paint
Offline Brazen17
« Reply #12 on: February 01, 2011, 12:17:57 PM »
I used high temp paint from Auto Zone. Although it has darkened a bit with time it shows no signs of peeling, cracking, or burning. It's been on there for about 2 years now.   :thumbs:
« Reply #13 on: February 01, 2011, 01:26:59 PM »
Took the cover off today and went with the high heat powder. I'll find out in the spring how it holds up. Lots of colours available. Could have done it in black or in silver.   :D
I picked silver...
He has my rocker cover, my coil cover, the DDM charge tubes, GMPP CAI and the turbo shield. It'll be nice and shiny under there!   :D
Offline JimVonBaden
« Reply #14 on: February 01, 2011, 03:15:06 PM »
I picked silver...
Nice, can't wait for the photos!
Jim :cool:
Offline spider
« Reply #15 on: February 01, 2011, 07:16:20 PM »
2500 degree ceramic coating, same as exhaust manifold.
« Reply #16 on: February 01, 2011, 07:30:12 PM »
Not half as much as me.  :D
If the high heat powder doesn't do it, that's next. I'll do satin black then.
« Reply #17 on: February 01, 2011, 10:16:49 PM »
The one I have was spray painted by it's previous owner and the heat ruined it. No idea what type of paint was used.
Offline SolNut
« Reply #18 on: February 01, 2011, 11:22:57 PM »
Polished mine, then applied a Pontiac Die Cut Decal (~2.5" tall), then a quick trip to the bead blaster.
Looks great after I removed the decal.  :thumbs:
I know,,,, I need a photo.  Right now only have my Netbook and the photos are unavailable.  :banghead:
 :ttiwwpic2:
Sorry!
Steve
 :drive:
