Author Topic: Spec FW with HOT SPOTS???  (Read 29258 times)
Offline spider
Re: Spec FW with HOT SPOTS???
« Reply #25 on: February 27, 2011, 07:45:31 PM »
Sounds like either the hydraulic hose was not routed in the proper avenue, for it will not gravity bleed elsewhere!! Or there is a location issue with the flywheel/clutch assembly. Hmm.
« Reply #26 on: February 27, 2011, 07:51:09 PM »
Are you saying that you had to use the entire travel of the pedal to engage and disengage the clutch? That does not sound correct at all. If the clutch action starts either at either end of the travel, something is very wrong.
On a manual (mechanical clutch vs hydraulic) clutch, if the pedal action starts real high then the clutch is adjusted too tight. Not a problem until there is some wear, and then slip will start. If the clutch action is real low, the shifting action will be bad and (you guessed it) gears will grind.
there's about 4"-6" travel between the clutch pedal and the floor right?  Can't recall.....its been awhile.  I have a manual POS car at the moment :)
doesn't have to travel all the way  for clutch to engage and disengage.    But I think the clutch was adjusted too tight. :(     It was the first time for that Saturn dealership to work on an LNF sky's clutch replacement.
« Reply #27 on: February 27, 2011, 07:58:51 PM »
I'm talking about a dry film lubricant thats 1/2 tho. moly based with binders . As far as I know it is only available at Polymer Dynamics hense the reason it beat out all the others & was chosen by Nasa for the Chariot. We normally use it for bearings with unbelieveable results. The smart race teams & individuals use it in transmissions & the input shaft (clutch dust sticks to greasy stuff)
I used a' brush on wipe off, thin film of anti seize on my input shaft because I wasn't willing to go into my tranny when replacing my engine. If you like I will talk to Carl about sponsorship being he recently dropped Grave Digger. If so get your notes together & I will tell him & send you his direct e-mail address.
Never really had to deal with any transmission stuff.   I'm trying to learn as much as I could right now  :)
So any help in improving the tranny's durability and shifting will be awesome!
Its nice to learn about new stuff!
I'm no Gravedigger though!  But my sponsorship proposal is always available and ready to go and get help with anything possible! :)
thanks for all the education today :)
Offline spider
« Reply #28 on: February 27, 2011, 08:04:14 PM »
Unfortunately there is no adjustment on these. Mine is about 3" off the floor ( the honey hole) Up high you just feel the pressure of the return spring, which is there to push the pedal back up giving you a second chance to get some fluid movement if pressure is lost. Mid way is normal & ideal.
What is your dispose-a-beater, mine was a clapped out '88 Celica convertible (sweet!)
« Reply #29 on: February 27, 2011, 08:09:41 PM »
I still represent a Saturn!!! :)
its a 2000 Saturn SC or sumthin.....
got it for $700.....w/ 160,000 miles
I drove since November.....and up to the present winter season...w/ no problems (except not starting in the morning).  I have to replace the fuel pump and coolant sensor
Offline spider
« Reply #30 on: February 27, 2011, 08:10:26 PM »
Again the routing of the clutch slave hose to master is crucial as is the clutch pressure plate's mating surface to throw out bearing mate.(not sure how to measure that)
« Reply #31 on: February 27, 2011, 08:11:39 PM »
anybody here knows about this and could help out?
speak or forever hold your peace! :)
Offline spider
« Reply #32 on: February 27, 2011, 08:16:59 PM »
Oooooooo sweet ride. Bet you get loads of compliments! I used Gaff tape twine.... on mine. No reverse was fun also. Woot! Woot!
« Reply #33 on: February 27, 2011, 08:17:58 PM »
There is NO adjustment on our clutches. None. The SAC does the "adjusting" by keeping the pedal action the same as things wear, and when the clutch is used up, the travel will still be the same but there will be slip. On a non-SAC you have what you have, and there is NO adjusting for wear.
« Reply #34 on: February 27, 2011, 08:22:53 PM »
yup, that's the only problem with NON-SAC.
but I can't go back to the oem clutch.
« Reply #35 on: February 27, 2011, 08:47:37 PM »
And THAT is the OTHER issue with non-SAC stuff.  (At least for me.)
Offline spider
« Reply #36 on: February 27, 2011, 10:38:14 PM »
Ok, the clutch hose needs to be routed above the rubber boot for the steering column & also above the grommet for the hood release cables. If not it will be very difficult or impossible to bleed properly. Its easy to not do it this way, so keep this in mind when going back together.
« Reply #37 on: February 27, 2011, 10:54:54 PM »
thank you bro.
I appreciate it.
Offline Graywolf
« Reply #38 on: February 27, 2011, 11:16:21 PM »
I have been running a Fidanza flywheel and spec 3 clutch mostly on road racing courses last year. So far everything has worked well. I put 500miles on new engine and clutch before I started racing it. Talked with the guys from spec at SEMA show this year and they seem to be a good group of guys.
« Reply #39 on: February 28, 2011, 03:59:50 AM »
Graywolf: thanks for you input, I was looking for a different setup. How is daily driveability? Any chattering, sounds, engagement force, things like this which can become annoying fast.
« Reply #40 on: February 28, 2011, 09:00:20 AM »
Just to make sure that it is clear, the Fidanza flywheel will only accept STOCK (self adjusting clutch / SAC) style clutches and pressure plates. And, it has a replaceable friction surface so not machining required if worn or hot spotted.
« Reply #41 on: February 28, 2011, 09:10:46 AM »
so how was Tom (graywolf) able to use Fidanza FW on his spec stage 3?  I got confused there! :(
also, The advantage of the Fidanza will be.....it will be cheaper to replace that friction surface VS replacing the whole spec FW :(
But in regards to getting into it........it will be the same 9 hour labor fee of regular clutch job if I replace my spec FW, dont you think?
« Reply #42 on: February 28, 2011, 09:12:59 AM »
SKY888: SOB was trying to explain that situation, you can get Fidanza FW but only with SAC version of Stage 3+
« Reply #43 on: February 28, 2011, 09:18:30 AM »
oh ok, got it! :)
« Reply #44 on: February 28, 2011, 09:20:00 AM »
Reason why I got the non-SAC, which SPEC specified:
This package converts the restrictive and vague factory SAC type pressure plate to a SPEC exclusive billet 360 degree pivot unit with higher load/rpm ability, better drivability and longer life than can be achieved with a modified factory design.
« Reply #45 on: February 28, 2011, 10:01:20 AM »
UPDATE:
I just talked to SPEC and they told me that hot spots on the FW could be normal or abnormal.
They need me to send photos of the flywheel, and both sides of the disc and pressure plates.
Then they'll be able to let me know what's going on.
I will not get my stuff from cryo-treatment til tomorrow.....then I'll take photos to send them.
Until then....we're still on stand still.
Also, SPEC stated the the FW also has a replaceable surface..............
« Reply #46 on: February 28, 2011, 10:05:26 AM »
« Reply #47 on: February 28, 2011, 10:05:59 AM »
Hey 888, since the car has been apart for a while, another week or two won't hurt. Send the stuff back to them to inspect !!!!!!!!!!!!!!!! Cameras DO lie. If people look at pics of mechanical parts, lighting DOES make a difference, but if they have the parts IN THEIR HANDS ......................
edit --- just saw the pics. Send in the stuff. They need to see AND feel the surfaces as well as the surface of the clutch as well. If you send ALL THREE PIECES to them, they can also measure everything as well.
« Reply #48 on: February 28, 2011, 10:11:14 AM »
SOB, actually the problem is at the shop.  They want this finished ASAP, since there are other projects waiting.  They only have one lift......and I can't afford any delays for my project.    All my sponsors are also bugging me and asking for updates and stuff.   I personally already waited long enough, and I can't wait too....lol
Shipping back and forth the the flywheel/etc will just cause me the same money such as buying a new friction surface ($70-90).
« Reply #49 on: February 28, 2011, 10:18:06 AM »
Good to know this piece of information  :thumbs:
