Author Topic: Tunned with Meth (Dyno Sheet Included)  (Read 26941 times)
Re: Tunned with Meth (Dyno Sheet Included)
« Reply #25 on: March 04, 2011, 02:01:32 PM »
Here are the before and after of the meth:
and here they are in a little nicer looking excel graph format:
It was fun tweaking the setup and getting mike some more power. What was really crazy was when the car first showed up it was only making about 260hp. The reason was that the meth was spraying pretty hard without a tune to take advantage of the meth being sprayed. That is the reason that if you are going to put meth on the car, make sure you get a tune to take advantage of it, otherwise you are probably going to make less power and torque.
Hope that helps,
Dave
« Reply #26 on: March 04, 2011, 02:06:06 PM »
Well the stock windshield indicator comes on when its low, I also have a light that tells me when Im spraying..
How about when the donkey is spraying?
Offline IBDRINKEN
  • Donkey Master
« Reply #27 on: March 04, 2011, 02:15:02 PM »
Thanks Dave for posting this..
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #28 on: March 04, 2011, 02:24:42 PM »
Thank you Dave for another strong documented modification  :thumbs:
The difference in mid rpms is awesome  :drool:
I have a question, my brain can't compute why there is a difference also in low rpms (under 3000rpm)? When the meth starts to spray?
« Reply #29 on: March 04, 2011, 02:40:44 PM »
The difference at low rpms is also from the meth being there and allows a little more timing to be added in without getting any detonation. The meth kicks in around 11psi on his setup.
« Reply #30 on: March 04, 2011, 02:46:00 PM »
Again THANK YOU MASTER YODA :D I thought meth comes in on full boost and I was thinking (wrong) the differences will be seen only after 3000rpm.
Damn, this is awesome, I can compare with my nitrous spray, overall this is better and I think is better on streets and AX, nitrous being more proper for drag racing or high speed straight racing.
Offline IBDRINKEN
  • Donkey Master
« Reply #31 on: March 04, 2011, 02:47:37 PM »
I think Dave has talked me into getting Nitrous..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #32 on: March 04, 2011, 02:50:06 PM »
He got you on meth, now on nitrous? what will be next? :lol:
I like nitrous a lot also  :drool: just make sure you don't inhale it or than the fun starts
« Reply #33 on: March 04, 2011, 02:50:36 PM »
NOS will definitely be a huge advantage compared to water/meth POWER wise.
but NOS only last for a few runs......then you have to refill it again.  Very expensive.
You only use NOS once in a while....or at a strip.  So depending on how big is your bottle.....you will be spending $50 and higher to fill it up....for using it at a few runs.
Water/meth....you can use EVERY SINGLE day.   Refilling it is very cheap.   You can use windshield wiper fluid for like...  $2 or sumthing.  That gallon will last you for a week.
POWER - NOS wins
if you want some power...........and great value for your money.......water/meth wins :)
« Reply #34 on: March 04, 2011, 02:52:12 PM »
water/meth + NOS = AWESOMENESS!!! :)
« Reply #35 on: March 04, 2011, 02:58:56 PM »
Antonio seems you are not updated, there are nitrous controlers (I agree they are expensive) which allows progressive shots and can easily used on streets or even on circuit racing ;)
I agree about nitrous bottles, that's I have 2 in my trunk all the time :))
« Reply #36 on: March 04, 2011, 03:08:15 PM »
my friend has a NOS controller.
He still uses his NOS kit when he's at the track, and not on the street....since NOS refilling is expensive, which I stated numerous times :)
« Reply #37 on: March 04, 2011, 10:10:20 PM »
Good numbers, now go back to the track and see how much you can shave off that 13.5 at 101.90 mph.
Base on what you have on that Dyno you should click 12.6 - 12.7 with Drag Radials.
« Reply #38 on: March 05, 2011, 12:25:20 PM »
 I pay around 55.00 in Maryland for a 10LB Bottle ,Unless I'm at DDM's . The Co. there only charged me 35.14 And they Did a Great Job . In Co.Springs it was 45.00.  So it Varies from State to State and Shop to shop .What ever the Traffic will Bare
« Reply #39 on: March 05, 2011, 12:35:57 PM »
I will be getting water/meth put on at the mod meet with the 2871 turbo upgrade.  I am very excited...that's going to make some serious power.  I hope they are able to bring the dyno.
Offline IBDRINKEN
  • Donkey Master
« Reply #40 on: March 05, 2011, 12:50:09 PM »
you will def love, you just have to decide on what mixture your going to run. I prefer the 50/50 mix
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #41 on: March 05, 2011, 01:05:18 PM »
I will probably go 50/50 as well...I use the car as a daily driver and probably will set the water/meth to spray at around 11psi so it doesn't get wasted around town.
Offline IBDRINKEN
  • Donkey Master
« Reply #42 on: March 05, 2011, 01:08:00 PM »
Thats what dave set mine at. Since I have left DDM on Thursday, I havent sprayed yet.
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #43 on: March 05, 2011, 01:50:53 PM »
stop talking about water/meth..
you are giving me ideas....
also stop talking about DDM 2871...you are also giving me ideas...
BUT, you have someone to resbonsibly do the install...around here, no such luck
« Reply #44 on: March 05, 2011, 02:05:13 PM »
Arabas: you should put ideas into practice stop blaming various reasons  :slap:
« Reply #45 on: March 05, 2011, 03:03:39 PM »
HA HA that's why DDM will be installing mine.  A perfect install is worth the wait.
Offline Brazen17
« Reply #46 on: March 05, 2011, 03:44:34 PM »
It appears GJ seems to know a few things about spraying!   :rofl:   :poke:
« Reply #47 on: March 05, 2011, 06:14:00 PM »
to be honest, since my poor results with the big wheel, i would like to see the 2871 kit tested first, read people's impressions, hear some real life driving with it, maybe some track races against stock turbo and then go with it.
that and also 2 more reasons: short on money right now and worried about internals with higher power.
i would like to avoid meth, so, i will just wait to see what people that will try the 2871 w/o meth have to say about it.
« Reply #48 on: March 05, 2011, 06:44:25 PM »
I spoke with Dave today about internals....if we don't go over 400whp, they should hold up fine...he said with the 2871 and water/meth, I would be ok without having to change any internals.
« Reply #49 on: March 05, 2011, 06:49:56 PM »
i'd like not to use meth if this is possible, just to avoide the xtra cost, hassle and worry about it running out etc etc.
i like this kit because it is from DDM who seem to know very well what they are doing. at last a complete kit with full support!!!
but in my case, it will be more expensive, new turbo to work on (+600) and new ecm to be bought by ddm, tuned and then shipped to me (+around 250).
so i want to have a real good image of what i will be buying in the future.
Steve pls let us know of your impressions when you install it.
