I borrowed a Porsche Boxster front caliper and I am testing with it.
Advantages of this caliper:
a) Weight, it only weights 2.6kg
b) Monoblock design (no bolted 2 parts caliper)
c) Cheap (2nd hand)
d) Full range of racing pads
e) Easy to fit
This caliper is originally fitted to bite a 299x24 disc brake, almost the same as our stock front rotors. I removed a pad from the Porsche caliper and put on the disc braking surface, the pad fits perfect, no more no less, so good news.
The set up I am looking for is:
Rotora 330x30 4p front (done)
Stock 297x25 disc + Porsche 4p rear
As you can see, the pad area is very similar to the Rotora pads. The whole caliper is almost same size to the Rotora 4p
I had a set of brake lines that fitted the calipers... I would need and adaptor on the other side of the brake hose.
Weight (In kg)
This caliper fits pretty well our discs, you only need to make your own brackets + brake lines. So here you have a cheap and good mod.
