Author Topic: " what was found "  (Read 3334 times)
" what was found "
« on: March 31, 2011, 08:58:23 AM »
 Well I got my solstice back Wednesday . They found that the serpentine belt was jumping on pulley rail causing false misfire codes. They said the same thing I said, How could it. Took them almost (2)weeks to search and check other things first.  If this is not it I'll make it blow up or something. The GM rep. said they will compensate me for the time I've been without ..WE will see !
 I went to google put this in ------> bad serpentine belt cause false misfire code
  found Caddy w/misfire  P 0300 all(8)cylinders were misfiring and other cars
Re: " what was found "
« Reply #1 on: March 31, 2011, 09:09:50 AM »
The real question is...
How does she drive???
Welcome back to the "group"!!!
« Reply #2 on: March 31, 2011, 09:13:19 AM »
Unless the serpentine jumped off and whacked the crank sensor sitting right behind the pulley.  I don't suppose the crank sensor is located there, correct ?  Also, does that mean the crank pulley was bad enough that the belt was misaligned ?
Mind boggling.
« Reply #3 on: March 31, 2011, 09:25:59 AM »
The ECM
Mind boggling.
It is not sensing the actual misfire, but rather the subtle uneven rotation of the crankshaft. Having a belt slapping around could certainly cause the ECM to be fooled.
« Reply #4 on: March 31, 2011, 10:18:01 AM »
Bad belt tensioner?  What did they do to correct it?
« Reply #5 on: March 31, 2011, 11:34:45 AM »
well drove her about 10 miles and taking her out today. So far so good .
The tensioner was not bad.They changed the belt
Mind boggling.
I don't know how ,they just said it was hitting side of pulley.
The ECM It is not sensing the actual misfire, but rather the subtle uneven rotation of the crankshaft. Having a belt slapping around could certainly cause the ECM to be fooled.
Right  Bob giving a False code.
Now  Go to (google)type in ----> bad serpentine belt cause false misfire code   --->   click search
