Author Topic: Who has a oil pressure gauge installed in their car?  (Read 6072 times)
Offline Graywolf
« on: April 07, 2011, 10:27:44 PM »
I am interested in finding out how many of you have installed a oil pressure gauge in your car. Secondly, has anyone noticed a drop in pressure during Drag,Autocross,or Road racing etc. Since I am one of the unlucky that blew a engine last year [piston] that was not covered by warranty, we need input to help prevent engine failure. It is well documented that piston failure occurs[oem pistons suck]
Offline IBDRINKEN
  • Donkey Master
Re: Who has a oil pressure gauge installed in their car?
« Reply #1 on: April 09, 2011, 01:15:48 PM »
I have a oil pressure gauge in my car and it stays steady around 158
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Offline shabby
« Reply #2 on: April 09, 2011, 01:30:58 PM »
158 psi?
« Reply #3 on: April 09, 2011, 02:04:25 PM »
Per GM's shop manual the LNF should have a min oil pressure at 1000 RPM of between 50-80 PSI.
« Last Edit: April 10, 2011, 01:47:12 AM by Sol Asylum, Reason: RMP PRM MPR take your pick »
Offline IBDRINKEN
  • Donkey Master
« Reply #4 on: April 09, 2011, 02:31:44 PM »
shit I def mistyped that. I ment 94 constant
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline MARVIC 1
« Reply #5 on: April 09, 2011, 07:21:44 PM »
That's a big "mistyped" mistake, numbers don't even match for a mistake... "158" - "94:poke: :D
« Reply #6 on: April 09, 2011, 11:24:06 PM »
And THEN there is 50-80 psi at 1000 RMP. Coolness.  :D :D :poke:
Offline IBDRINKEN
  • Donkey Master
« Reply #7 on: April 10, 2011, 12:28:15 AM »
I was looking at the oil temp instead of the pressure...
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #8 on: April 10, 2011, 01:51:19 AM »
Fixed that typo for you Bob, at least I had the right letters just in the wrong order.
I like how the minimum is a range.  If you have 85 psi at 1000 revs is that too much for a min? :idk:
Offline Graywolf
« Reply #9 on: April 10, 2011, 05:08:17 PM »
Well i just replaced the sensor on my gauge . At idle 8 to 12 lb,then it goes to 38 @2600  43 to 45 @ 6000rpm. Since the sensor I used was not the same diameter as the original that came with the gauge,I'm guessing the gauge is a 0 to 60lb and the sensor I know is off a 0 to 100lb gauge. So I know this will make the numbers off,sorry I am not going to spend another $35 to put the correct one on it.This is the pressure off the oil line going to the Turbo
Offline shabby
« Reply #10 on: April 10, 2011, 07:47:19 PM »
That sounds a bit low for engine oil pressure, manual says 50-80psi at 1000rpm, for turbo oil pressure its ok.
Offline Graywolf
« Reply #11 on: April 10, 2011, 11:22:34 PM »
Agree Shabby ,but I have never had an engine oil light go off. Using the wrong sensor isn't helping matters. I would think the pressure going to the turbo is the same as the engine but I might be wrong. Also of interest is the fact that it takes 3 to 5 minutes for oil temperature to catch up with the water temperature. So please make sure your engine is well warmed up before you race.
Offline davytudope
« Reply #12 on: April 11, 2011, 06:18:02 PM »
Where did you place the sender for the oil temp gauge
2007 solstice gxp
TEAM FAIL RACING
Offline Graywolf
« Reply #13 on: April 11, 2011, 10:54:34 PM »
I put a T connector off the oil line going to the turbo and ran the oil line to a electrical oil pressure sensor
Offline MGar
« Reply #14 on: April 11, 2011, 11:01:25 PM »
I do know that most turbos require a restrictor somewhere in their incoming oil line, especially if they are ball bearing turbos.
2008 GXP
Offline Graywolf
« Reply #15 on: April 11, 2011, 11:52:47 PM »
MGar, I wondered about a oil restriction for turbo but your the first to mention it. However,I would think it would be built into the turbo oil inlet.
Offline MGar
« Reply #16 on: April 12, 2011, 01:09:18 AM »
They are typically in the inlet.  However, I don't know in our particular application if that is the case because I have not gotten into it yet, as my turbo has yet to fail.
2008 GXP
