Author Topic: What code is this?  (Read 2615 times)
Offline IBDRINKEN
  • Donkey Master
What code is this?
« on: May 06, 2011, 12:25:44 PM »
So I had a cel light and this is what the codes read. Not sure what exactly it means. Fan 1 circuit low and cooling fan circuit malfunction. Any help is much appreciated
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Re: What code is this?
« Reply #1 on: May 06, 2011, 12:32:17 PM »
I'd guess (but it is a guess) it's your engine fan resistor block.  Seen others who posted that their connector had melted where it plugs into the fan speed resistors - they had to replace the resistor pack and the wiring harness piece.
UPDATE: Sorry, ignore the above.  I was confused with the heater blower fan that has that issue: http://www.solsticeforum.com/forum/f62/heater-ac-blower-stopped-working-68002/#post1029912
Apologies.
« Last Edit: May 06, 2011, 12:48:26 PM by TomatoSoup »
Offline IBDRINKEN
  • Donkey Master
« Reply #2 on: May 06, 2011, 12:51:36 PM »
 :slap: thanks tho..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #3 on: May 06, 2011, 02:27:15 PM »
he you used your car to jump another by connecting the jumper cables to the fuse box.  you will blow the radiator fan fuse and get that code
Offline IBDRINKEN
  • Donkey Master
« Reply #4 on: May 06, 2011, 02:29:11 PM »
I did jump my car with my jump box yesterday. Any idea on how much that will cost...
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #5 on: May 06, 2011, 02:31:36 PM »
It. is just a fuse
Offline IBDRINKEN
  • Donkey Master
« Reply #6 on: May 06, 2011, 02:37:02 PM »
Thanks I just went out and checked it and your right its blown..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #7 on: May 06, 2011, 03:20:39 PM »
Great, glad I could be of help.  Both of the fuse panel posts are "+".  Always connect the negative to the plate coming off the engine and you won't have any more issues.
« Reply #8 on: May 06, 2011, 03:22:26 PM »
6 billion dollars IB, I can pick one up for you if you like and fly down with it.  Hell I will even install it.  Just paypal the monies.
« Reply #9 on: May 06, 2011, 03:39:32 PM »
Critter your getting screwed, I found it on-line and can get it for him for just $5.9 billion, let me know what you want to do IB.
Offline IBDRINKEN
  • Donkey Master
« Reply #10 on: May 06, 2011, 03:41:41 PM »
My donkey is enroute to pick it up...
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
