Author Topic: Clutch vibrates when air on  (Read 2064 times)
Offline 2.0 tspeed
« on: May 07, 2011, 06:43:00 PM »
Well this is strange this morning I got in the car turned on the air and it sounded like rocks clanging all around and clutch would vibrate, turn air off noise would go away and no more clutch vibrating,
After car warms up , turn air on again rock noise gone but clutch still
Vibrates and feels a little off, car drives fine :-/ any ideas wasup
Clutch pedal just dosnt feel right
2013 verano turbo
Offline Gregory
Re: Clutch vibrates when air on
« Reply #1 on: May 07, 2011, 09:29:48 PM »
Turning the air on, did it engage the A/C? (surely did if the wind was on windshield)
« Reply #2 on: May 08, 2011, 05:43:20 AM »
 It is possible that your tensioner is not applying sufficient pressure and is allowing slipping. Have you had the belt off to inspect it and the tensioner? If the belt is dry or worn out it may be slipping.
Does the AC compressor make any noises, growling when it is engaged? A bad hub assembly makes a rattling, whinning or growling noise. The hub assembly can be changed and the clutch can be changed without depressurizing your system
taken from http://caddyinfo.ipbhost.com/index.php?showtopic=3071
