Author Topic: Possible site issue  (Read 45992 times)
Possible site issue
« on: June 17, 2011, 10:14:05 PM »
I have noticed over the last month or two that I will get an OOPS screen when I try to load a page or hit the back button like this one.
[attachment=1]
It doesn't seem to matter if I am at home, work, or using my phone so I don't think its an ISP problem.
Anyone else having this issue?
Re: Possible site issue
« Reply #1 on: June 17, 2011, 10:33:49 PM »
+1
I've been seeing that screen off and on at home and at work. Seems to be getting a little more frequent, however refreshing the screen usually solves the problem. When that doesn't, linking in from the home page does work.
« Reply #2 on: June 17, 2011, 10:44:07 PM »
Sol Asylum  I've been getting that and though it was something I did . some time it last a couple minutes and other times it last about 15-20 minutes. glad you posted it now I know its not just me.
« Reply #3 on: June 17, 2011, 11:04:54 PM »
Nope, not me.
Offline IBDRINKEN
  • Donkey Master
« Reply #4 on: June 17, 2011, 11:05:52 PM »
I get the eerror as well every once in a while..
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #5 on: June 17, 2011, 11:26:21 PM »
Yup, here too....
« Reply #6 on: June 17, 2011, 11:35:41 PM »
Me too
I've can almost recreate it when doing searches.
Offline Gregory
« Reply #7 on: June 18, 2011, 03:51:52 AM »
This thing happens to me too.
Could it be a bandwidth error? The members number raises rapidly :)
« Reply #8 on: June 18, 2011, 04:24:51 AM »
Could be, we have had growing pains before.
« Reply #9 on: June 18, 2011, 05:23:47 AM »
I get that and so does Reed. Each time we're like "Oh no, I crashed the forum!"
Sometimes hitting back helps. Other times I exit the forum screen and go back in from the home page and it's fine.
Offline Whip
  • Global Moderator
  • Air Force Retired
« Reply #10 on: June 18, 2011, 06:27:31 AM »
It happens to me on a daily basis but only on my work computer.  Sometimes hitting the back button works but more often than not I have to exit and reenter.
GMPP Stage II Tune
Deepblue turn signal mod
Burl wood dash
« Reply #11 on: June 18, 2011, 06:43:35 AM »
same here sometimes...
at first i thought that GJ hacked my computer :)
« Reply #12 on: June 18, 2011, 08:00:31 AM »
This happens for two reasons.  database errors or server problems
I have noticed it also and I've called tech support, they tell me that the server is over tasked.  They stated one of their users is violating their terms of services (didn't know it until I complained) and when they identify which one, they will terminate their account.  The problem should resolve itself.
Usually I can tell right away if it's a server or database error.  If it's a server error like I wrote about above, I won't be able to connect the HostGator Admin page to do maintenance
I run maintenance every morning and perform backups, yesterday is when I called tech support because I could connect to either.
« Reply #13 on: June 18, 2011, 08:10:01 AM »
Joe, sounds like terminating the account will set things right?  But if the server is over tasked does that speak to another issue or are we ok?
Ron
« Reply #14 on: June 18, 2011, 09:27:35 AM »
Yikes, it's probably us! :lol:
« Reply #15 on: June 18, 2011, 10:03:37 AM »
That sounds BS to me, they must know in every moment what happens on their servers, they don't have to wait to identify, read the logs and they have the answer
« Reply #16 on: June 18, 2011, 12:34:49 PM »
:agree:  If they can't tell who is causing the problem they should be shot.  At gun point!
Is this something that's browser-specific?  I use Firefox and never see the problem, though I do see some long refresh/update times on occasion.  Of course, maybe it is a server response issue and some browser(s) just don't handle it well.
For those who see the issue, are you all using Microsoft IE (and which version)?  If not, which browser?
« Reply #17 on: June 18, 2011, 01:07:38 PM »
I use Firefox and Chrome and happens on both, the error generally is db connection or 500 error (server), don't think this is a client side problem, hoster confirmed there is a problem with the server.
« Reply #18 on: June 18, 2011, 02:00:22 PM »
I get it one all  I use
Safari, chrome and IE7 and 8
« Reply #19 on: June 18, 2011, 02:16:41 PM »
Drunk post?  I hope you got Ihawks permission this time.
« Reply #20 on: June 18, 2011, 07:50:48 PM »
Yes...this is buzzed post # 1. I should start a thread! :)
« Reply #21 on: June 18, 2011, 08:07:28 PM »
You know oddly enough drunk posts could still be on topic as it may end up being a site issue.  Or would it be a sight issue?
« Reply #22 on: June 18, 2011, 08:36:10 PM »
Possibly both! All I know is it's early and I can tell this night will not end well!
 :barf: :barf2:
« Reply #23 on: June 18, 2011, 08:39:41 PM »
And you didn't invite me? :idk:
« Reply #24 on: June 18, 2011, 09:01:41 PM »
Don't tell her but I'm the recipient of the drunk texts and she can't have them ;)
