On the way home from work on Friday, the suspension was cycling really weird. I thought maybe I had adjusted the coil overs differently, so I went back and zeroed all of them, and then took a test drive today.
That did not fix it. Car was doing this weird wag the tail type thing. I could not tell if it was the front or the rear but man was it not cool.
So I just spent a bunch of time going over everything on the suspension front and rear. My Back is F-Ing Pooched.
Here is what I found.
Passenger front - MISSING one of the 2 nuts that hold the upper Coilover. Had to take the remaining one off and go to Lowes to get a match.
Took the car out for a test drive. Still wagging the tail. WTF???
So I take off both rear tires.
Driver Rear - 1/2" gap on the lower ball joint Nut holds the lower A-Arm. What a Pita that was to fix. The Axle is in the way of getting an Allen head to hold the bolt while you tighten the nut.
I was lucky enough to have a 90 degree allen head. Once I finished tightening down the nut, the Allen head was wedged against the axle. So I basically had to strip the bolt to pry the allen head out.
