Author Topic: What did you do to your Kappa today - Part 2  (Read 1539360 times)
0 Members and 13 Guests are viewing this topic.
Offline Kagem
« Reply #1750 on: July 28, 2012, 01:07:27 PM »
Put a custom six-piston brake kit to the local tuner that made my ic one and a half year ago, he makes the calipers and the 13,58'' inch rotors are aftermarket. A big thanks to Dave 'elff' for helping me have another option with the brakes he has to his car, it was really hard to decide. The price for these brakes placed in the car is 1400 euro, pretty good price for our market. The first impressions are really good, finally i have the confidence that the car is going to stop when needed, press them hard and voila you have a seat belt mark on your chest. Some fotos....
« Reply #1751 on: July 28, 2012, 01:16:28 PM »
Ironhide let me know when you are going to be in the Chicago area, I am not too far from there and actually should be in the area in late Sept.
« Reply #1752 on: July 28, 2012, 01:30:33 PM »
Looks good Kagem
Crazy Color!!  Love it
Congrats Ironhide
Offline Kagem
« Reply #1753 on: July 28, 2012, 01:35:19 PM »
Thanks, the colour was almost my only choice from the beginning, i have the weitec suspension which is green and yellow ( http://www.lohen.co.uk/shop/prodimages/Gen2Weitec_medium.jpg ) and so my choices where these two colours to match the suspension. But regardless that, i would go for green anyway....
« Reply #1754 on: July 28, 2012, 02:00:02 PM »
I wonder why they painted/powder coated the bleed nipple.  Won't that mean you'll crack the finish the first time you bleed the brakes, when you install them?  Usually, the caliper is painted before they add the nipple, and the hard line for both sides of pistons.
Offline Kagem
« Reply #1755 on: July 28, 2012, 03:11:08 PM »
Well i'm not an expert for this, and maybe you have a point, i guess they knew but if the colour fades i'll go and have them repainted....
« Last Edit: July 29, 2012, 01:33:53 PM by Kagem »
« Reply #1756 on: July 28, 2012, 08:13:51 PM »
Don't worry about the bleed nipple.
Today I tested the E85 at the station I go to.  I wanted to verify it was currently a summer blend and it is 85%
« Reply #1757 on: July 28, 2012, 08:42:07 PM »
Kagem ;   I'm gonna be over there next month ,hope I get to meet you also (Bobby)
« Reply #1758 on: July 29, 2012, 01:19:49 AM »
It won't affect performance, but I would think the first time you bleed them, which is when you install them, you'll crack the finish, and as a result, it starts an edge for the existing finish to start lifting from.  And to be honest, this is the first time I've seen the nipple painted over before.  For example, if you look at mono block style calipers like yours from Brembo or that come stock on vehicles, the nipple is always installed after the painting/powdercoating to make it last longer.
But like others have mentioned, looks like a good brake setup.
« Reply #1759 on: July 29, 2012, 02:06:19 AM »
The powder coat will not peal like a liquid paint will, it might chip but I don't think you will have much more then a crack that runs around the threaded portion of the nipple.  You could always just replace the nipples but I don't think you will have much of an issue with the powder coat failing.  The real question is how does powder coat react to break fluid?
« Reply #1760 on: July 29, 2012, 02:24:29 AM »
The problem is it's aluminum and aluminum loves to oxidize.  And that's why it does not need to be finished.  It will oxidize and form a protective layer.  But when that oxidized aluminum forms, it expands as it takes on oxygen.  That forces upwards against whatever material it's up against at that edge that is just beginning to oxidize.  So the more flex the material coating it is, the better chance it has of resisting this small amount of relatively protective oxidized layer.  But if the powder coat or paint is brittle, that oxidation along with repeated heat cycling and the accompanying thermal expansion/contraction, it's only a matter of time before the finish will start lifting off.  Which is why they usually don't paint over the nipple.  Which is why I've never seen it before, and why I said I wondered why it was done that way other than whomever thought of having them powdercoated didn't know better.
Good thing this will only affect aesthetics and not performance.  Which is the important part.  And if the powdercoating was done properly, it should still last pretty long.  But I wouldn't be surprised if the cracked edge led to more material lifting off over time.
« Reply #1761 on: July 29, 2012, 05:00:56 AM »
But powder coat is flexible that's why they put it on things like springs.
If they had put a silicone plug in the hole and then powder coated, you would still have an exposed edge between the powder coat and the aluminum.  If they didn't plug the hole then maybe you would have powder coat that got into the thread which then may have to be cleared out just to get the bleeder installed which would bring us back to an exposed edge.  There is also the chance that the powder would never have gotten down into the bore because of how the electrostatic charge of the powder draws the powder to the closest surface.  Would I have powder coated them the way they did, no, but will it make much of a difference, probably not.
How the part oxidizes depends on what alloy was used to make the part and how they prepped the part, if they preoxidized the part then there's no issue.  As you said the oxidation forms a protective layer so even if there is an exposed edge the oxidizes that could form should prevent filiform corrosion from happening.
Chances are the powder coater has done this in the past and had no problems and that is why they did them this way, if you notice they did mask off other parts of the caliper and you can see bare aluminum which kind of negates the whole bleeder being powder coated issue.
I guess another question would be did they use a powder coat that will take the high temps brake components see?
« Reply #1762 on: July 29, 2012, 08:05:39 AM »
Split all of Carbon Sky's stereo info to this thread
http://www.kappaperformance.com/forum/index.php/topic,9021.0.html
Offline Rogue
« Reply #1763 on: July 29, 2012, 08:58:55 AM »
To answer the thread question "what did I do to my kappa today" well....I washed it. For the first time in over a year. We're going to the local Pontiac club picnic this afternoon and we wanted to get the garage dust off Rogue. We thought it would be a good idea to drive him to the event. He's only had 600 miles put on in the past year. All the way up to 3600 miles now. Oh yeah, forgot to mention, we did install one of the DDM center consoles. Very nice. Also, Rogue made it as a calender car for the Pontiac club calender for 2013!
Go N.A.K.3.D..
Offline Kagem
« Reply #1764 on: July 29, 2012, 01:22:51 PM »
Hey Bobby it's really a good opportunity but from mid August till the end of it i'm going to be on vacation away from Athens. Many of us will be on vacation next month, if it was some other time i for sure would be there.
Carbon sky i see what you mean, i didn't know i am just realising it. This local tuner is only 3 miles away from me so i'm there in 5 minutes if something is needed, thanks for the info!
« Reply #1765 on: July 29, 2012, 01:29:47 PM »
Admit it Kagem, your scared that Bobby will see how slow your Greek Tuned 2871's are compared to mine.
Offline Kagem
« Reply #1766 on: July 29, 2012, 01:41:34 PM »
You uncovered me, damn! Yes that is the real truth, this is what we fear, we don't want to loose our reputation of the fastest kappa's on the planet  :lol:
You know what, we find some supercars, we pay their drivers to pretend they are slower than us in the race videos we make  :rofl:
« Reply #1767 on: July 29, 2012, 01:46:27 PM »
 :lol: :lol: :lol: :lol: :lol: :lol:
Actually, Kelu has a good tuner.  He got great results out of his 3071.
and
I got to see his Sponsors GTR.  Soooooo Nice
Offline Kagem
« Reply #1768 on: July 29, 2012, 02:25:03 PM »
That is not a car, please! Is it a train, is it a plane?
« Reply #1769 on: July 29, 2012, 07:52:35 PM »
Thank you Kagem for such nice words about my GT :lol:
Offline Brazen17
« Reply #1770 on: July 29, 2012, 07:58:54 PM »
Started to clay bar and buff out my wife's RL. Noticed her headlights were really hazy. Going to take a lot of work to get those babies back in shape.   :)
OK. GJ and SA should have a field day with this post...  :rofl:
« Reply #1771 on: July 29, 2012, 09:14:46 PM »
Parked the car this afternoon and pulled up too close to the railways ties that lined the edge of the lot. The bumper pushed back and the inter cooler grill came out of it's clips. Took the bumper off, clipped the grills back in place and all is good. You can't tell anything happened to the bumper except for one thing.
Car looks different now though 'cause the Aftershock grills fell out. The stock grills are back on the car for now. Much prefer Rudy's grills.
When the bumper flexed the tabs all broke off the back of the grills. I should have known better as I always try to pull up short 'cause the car is so short anyway.
Some time ago I got clear bra material put on the outer ring of the grills but the job wasn't done all that well. The guy that runs the place asked me to bring the grills in and he would redo them. When he did them the first time I had fastened them to a board so it was easy for him as he was only charging me $20 for material. I had already installed them on the car and didn't feel like taking the bumper off to get them covered again.
Here's my oppotunity. The grills are still in good shape as the clear bra material saved them from any damage when they hit the ground. I glued all the tabs back on except the one I couldn't find. I'll fix that with a small screw from the back when I reinstall them. It's stock grills for a week or so until I ge the recessed grills ready to reinstall.
« Reply #1772 on: July 29, 2012, 09:27:57 PM »
 If your on Vacation  There is a Car show being put on by  (Hemmings Motor Sport) in Istanbul on Saturday 8/18 /2012
 from 9:00AM til Noon I will be there also .      :yay:      "  Bobby "      :yay:
Offline Kagem
« Reply #1773 on: July 30, 2012, 01:27:47 AM »
Wow that's nice! I am not leaving the country, you better post some pictures of that show!
Kelu wtf, i was talking about the nissan, but you knew that! Ok ok your gt is a nice one too! Also, i met a friend of yours here Michael, i told him to send you my regards! I saw him again the other day, he told me he did!
« Reply #1774 on: July 30, 2012, 02:27:48 AM »
I was just teasing  :poke:
:idk: Not sure who you are talking about
