Author Topic: What did you do to your Kappa today - Part 2  (Read 1258255 times)
Offline 06CoolSolstice
« Reply #2400 on: October 30, 2012, 09:14:33 PM »
It is a Saturn Shifter, both the shift knob and the leather boot.  I think Joe bought a bunch for the trim ring and was selling the part he was not using.  It was $5 for the part and 15 for shipping.  Here is the post I found from last year, I called him and he had some left.
http://www.kappaperformance.com/forum/index.php/topic,7789.0.html
Garage:
2006 Solstice N/A
2001 Suburban (wife's)
1998 Trans Am
1974 Corvette Stingray
2007 Trailblazer SS (sold to by Sol)
Offline Ironhide
« Reply #2401 on: November 03, 2012, 07:55:45 AM »
Now my GT is gone! :(
Shocked?
No, I didn't sell it!
I've rented a garage for winter and now my car will rest there till March. :cool:
I love kidding others!! :devil:
Oliver  :usa:
« Reply #2402 on: November 03, 2012, 11:39:52 AM »
Shocked?
That's just cruel!     :lol:
Hopin' winter's a short one this year.   :thumbs:
Online TomatoSoup
« Reply #2403 on: November 03, 2012, 04:25:21 PM »
Finally did the coolant check-valve TSB on my car today (TSB 10-06-02-001).  Went OK except it's a bugger getting the clip off the radiator pipe (intake tube's in the way) and then a bugger getting the pipe off the nipple by the cam cover (DDM's cross-brace in the way).  After those issues it was plain sailing though.
Also came up with my own version of the GM Vac'n'fill!  Got one of these from Harbor Freight (http://www.harborfreight.com/multi-use-transfer-pump-66418.html):
Pulled the return pipe off the overflow tank and pushed it into the pump intake (by the handle), then routed the other orange pipe from the pump back into the o/f tank.   Then I just pumped for a while 'til I stopped hearing any gurgling and just had a clean stream of coolant flowing into the tank.  Didn't have to unbolt the tank and raise it up, or do a "hand-job" (not in my job description!) or anything.
You can even get the pumps for $4 with the coupon that occasionally pops up in their ads.
Pretty sure I got some air out, 'cos the fluid level in the tank was about 3/8-1/2" lower than before I started.
« Reply #2404 on: November 03, 2012, 05:11:44 PM »
Cool.  Interesting idea in action.  I put the valves in, then raised the expansion tank, and saw tonnes of bubbles being pushed out.  And then the level in the tank dropped as well.  Had to put in a little more coolant at the end.
« Reply #2405 on: November 03, 2012, 07:38:10 PM »
Yeah I bought the valves to do it a few hers ago but never had an issue with the cooling system. The car's five years old now, or will be in the spring so when she comes out of storage it'll be time to change the coolant and put in the valves.
Great idea Mark!
« Reply #2406 on: November 04, 2012, 12:56:35 AM »
Great idea Mark!
Same, I had bought valves about a year into ownership, but didn't put them in until it was time to change my coolant just before 4 full years (don't trust Dexcool to go the full 5 years personally, and consider it cheap insurance).  When I put them in, I noticed a significant reduction in my normal coolant temp.  I went from about ~98* C to about ~86*.  Did yours do something similar?  What was it before and after?
« Reply #2407 on: November 04, 2012, 06:21:58 AM »
I won't be changing it until the spring so we'll see what happens then but yeah, now the temperature is around the 98 degree mark.
« Reply #2408 on: November 04, 2012, 07:25:42 AM »
Treated the weatherstrips
Online TomatoSoup
« Reply #2409 on: November 04, 2012, 10:13:45 AM »
I never had the bad problem with my cooling either, but it DID get hotter than I liked... with peaks up to 210-212 degF (~100 C) and normal running around 200 F.
I took it for a long drive yesterday and I got it to peak at 203 (normally in the low 190's).  So it does seem to have had an effect.  Similar results to what CS just said.
« Reply #2410 on: November 04, 2012, 11:09:16 AM »
Went to IHOP in the coupe with Denise and didn't see you know who...
Sent from my H866C using Tapatalk 2
Offline cdflint
« Reply #2411 on: November 04, 2012, 11:11:39 AM »
I've not had BAD temps even in the Southwest here but educate me please. What do these valves look like and where are they placed (photo please). I've only had high temps (215 range) in a mountain twisty run and some 210 range on some daily start and stops days. Normally I'm in the 196-203 on days that were 95-105 outside air. It seems normal but if I can better my cars engine, I'm all for it.
She's an 09 Brazen GXP.
Online TomatoSoup
« Reply #2412 on: November 04, 2012, 12:10:34 PM »
If you did a search on the TSB# I posted :slap: ... you'd find this:
http://www.solsticeforum.com/forum/f59/attention-no-heat-over-heat-issues-54741/index5.html#post938806
Offline DaveOC
  • Running Wisconsin
« Reply #2413 on: November 04, 2012, 12:12:48 PM »
The info is in a long thread over on the BB:
http://www.solsticeforum.com/forum/f12/solstice-gm-part-numbers-22079/
These two messages in particular if you don't want to wade through the entire thread:
http://www.solsticeforum.com/forum/826316-post7.html
http://www.solsticeforum.com/forum/938806-post71.html
The last link is to a TSB with pictures.
That TomatoSoup guy is quicker than most!  He beat me to it!
Aggressive #000741
Offline cdflint
« Reply #2414 on: November 04, 2012, 12:29:12 PM »
Thanks, I'll take a look.
Offline cdflint
« Reply #2415 on: November 04, 2012, 12:46:08 PM »
Well the valve is cheap enough now but the picture could be a little grainier to not see what needs to be changed out but I thank you for the direction and read. I'll look to use this method. Didn't DDM do a video on purging air?
« Reply #2416 on: November 04, 2012, 01:11:09 PM »
If you read the threads properly, it tells you exactly where to put them so even with the slightly grainy pics, if you are in your engine bay at the time, I don't see how you wouldn't be able to figure out where to put the 2 valves.  It's pretty obvious once you think about what you're doing.
« Reply #2417 on: November 04, 2012, 04:55:22 PM »
So you didn't get your waiver, and registration form?
« Reply #2418 on: November 04, 2012, 07:54:46 PM »
Hosed mine off then took a ride to sell my headlights , A Guy from Washington, D.C. It felt good in mid 50s i think
« Reply #2419 on: November 05, 2012, 08:47:31 PM »
Installed new pedals, clutch and brake easy, accelorator was a :censor: !  Yes I need to vacuum out the inside, but we are having Santa Ana's right now so I will wait for the wind to die down.
Garage:
2006 Solstice N/A
1998 Trans Am
« Reply #2420 on: November 06, 2012, 10:10:32 PM »
Do you need a set of wheels with your new pedals?
And yes, you need to clean up :)
« Reply #2421 on: November 06, 2012, 10:13:17 PM »
Still trying to sell that Audi?
« Reply #2422 on: November 06, 2012, 10:17:39 PM »
Yes I am trying to find time to come down and get them.
Garage:
2006 Solstice N/A
1998 Trans Am
« Reply #2423 on: November 06, 2012, 10:27:11 PM »
I sold one.  Oops.
Kidding.
Offline cdnmoondog
« Reply #2424 on: November 07, 2012, 01:07:26 AM »
Fixed a code P0236 myself after service could not find problem, in fact the probably caused it!
