I change my spark plugs, OEM plugs are the AC 41-108. After 65k they gap at .033. I went to a colder plug. Because I'm running the GMPP tune, with max boost over 23psi. The plug, Autolite XP5263, equivalent to the AC 41-102.The original plug for the early 07 GXP.
The Autolite XP5263 is not plug & play. Gap out of the box is .048. I gap then down to .035.
Did a compression test, miles 65k, from front to rear, 170, 170,165,170psi.
Mike
