Author Topic: What did you do to your Kappa today - Part 2  (Read 1418061 times)
0 Members and 15 Guests are viewing this topic.
« Reply #275 on: August 29, 2011, 09:25:57 AM »
May have to go lower but my driveway hits that front air scoop at stock height. Can't imagine what it will do now. Still need to lower a bit in the front but I assume it will on its own too.
Same here, YouTube advertises several ideas:  My concern would be if snow removal blades would rip em up.
Curb Ramp
« Reply #276 on: August 29, 2011, 09:55:36 AM »
Dave already sent me a file.
I still have to figure out how to use it.
Seems like there are 3 separate programs
Scanner and editor
:huh: :huh:
« Reply #277 on: August 29, 2011, 10:58:11 AM »
I was using a large quantity of 2s
« Reply #278 on: August 29, 2011, 09:51:41 PM »
I hit a large bird on my way home tonight. :(
My guess is a pheasant.  It came up from the nose of the car, looks like it skidded across the hood, hit the top of the windshield, and then went on over.  Top was up.
I stopped to look for any obvious damage and didn't see any so far. When I got home, I pulled up close behind the G6. I can see where the bird left a big mark up the hood in the dust, but still couldn't tell anything.  I'll have to check in the morning.
Hoping my good luck holds and there is no damage!
« Reply #279 on: August 29, 2011, 09:56:08 PM »
Don't worry is was just a peasant, there are more where that came from.
Amazing how one letter can completely change the meaning of things.
Offline DRM
« Reply #280 on: August 29, 2011, 10:18:38 PM »
Installed the Sky shifter with blue stitching in my Deep Solstice...Cool....or should I say DEEP....
« Reply #281 on: August 29, 2011, 10:19:54 PM »
Monty Python??
Good country girl that I am...I went back to look for the sucker!  But it was that strange time of the evening when the sun has just gone down and your headlights don't quite work yet, but it's too dark to really see much. It wasn't in the road, so it must have been in the ditch.  I was heading west when I hit it.  When I tried to make the ditch pass, there was traffic coming at me, so between that and the time of day, and heading back west into the sunset, I couldn't see anything.
Dang coyotes will have some good pheasant tonight.  :mad:
But hey...I get a new kill sticker!   :yay:
« Reply #282 on: August 30, 2011, 12:07:34 PM »
FINALLY got around to install the LNf fuel filter that I won at the last mod meet. DDM says that it takes about 30 minutes but to allow a few hours. Took me less than 30 minutes including getting the tools out and putting them back again.
The hardest part was retrieving the cap from the schrader valve after I dropped it through the intake manifold. The instructions don't say to do so but I took it off to check if there was any pressure in the fuel system before I started taking anything apart. There was none.
« Reply #283 on: August 30, 2011, 01:25:57 PM »
Monty Python??
I don't know, it made me think Mel Brooks History of the World Pt1:
Sir, the peasants are revolting!
You said it, they stink on ice.
Offline J_Bond
« Reply #284 on: August 30, 2011, 02:04:10 PM »
Ordered custom dash gauge-faces and lighting from blackcatcustom, ordered black face with blue LED. Having 'KAPPA' glow in the tachometer.
  Also ordered a new center armrest to send to JPM for black quilted leather.
Lotus skid-plate/diffuser for deleted rear valence arrived..... Not sure 'exactly' how it will best be attached....  lol
WERKS lightweight battery
Dyno-tuned ECM by HP-Tuners
SOLO Single Catback exhaust
SOLO header
SOLO High Flow Cat
Energy suspension bushings
Koni shocks
Pro-Kit springs
EBC slotted dimpled rotors
Hawk Ceramic pads
BLACKED-out everything...
Redline headlights
Gutted trunk
« Reply #285 on: August 30, 2011, 02:34:57 PM »
Sure you don't want to wait for: http://www.kappaperformance.com/forum/index.php/topic,6032.125.html
 :poke: just saying...;)
« Reply #286 on: August 30, 2011, 02:40:35 PM »
pls don't forget to write up a DIY and post pics!!
Offline J_Bond
« Reply #287 on: August 30, 2011, 04:13:15 PM »
LOL, I still have little faith this product is EVER being produced!!!!
SOLO header
SOLO High Flow Cat
Koni shocks
Pro-Kit springs
Hawk Ceramic pads
Redline headlights
Gutted trunk
Offline J_Bond
« Reply #288 on: August 30, 2011, 04:16:13 PM »
I will, for sure.  I'm still having some trouble with extending and re-hanging the rear muffler.  it needs to be pushed further to the rear, right now it's tucked so far back it can hardly be seen because the car is so low.
SOLO header
SOLO High Flow Cat
Koni shocks
Pro-Kit springs
Hawk Ceramic pads
Redline headlights
Gutted trunk
« Reply #289 on: September 03, 2011, 04:48:44 AM »
Finally got my evaprative fuel solenoid in the mail today.  It only took a few days over a month to get here.  Took me about 3 minutes to change it out.  No I just have to clear the code again...
I also ordered a SPEC 3+ Clutch Kit, a SPEC Flywheel and a WERKSracing Clutch Slave Cylinder Spacer today.  Hopefully it will all arrive by the time I get back from my vacation!
« Reply #290 on: September 03, 2011, 06:09:36 AM »
Def: you have a new slave cylinder, right?
« Reply #291 on: September 03, 2011, 06:15:36 AM »
No I don't.  I'm not that educated when it comes to clutches.  Do I need to replace that too???
« Reply #292 on: September 03, 2011, 07:31:07 AM »
Yes, is a cheap part (75-150) which is advisable to be replaced when you do clutch change. Also don't forget about brake fluid.
Offline HAMMER DOWN
« Reply #293 on: September 03, 2011, 08:59:31 AM »
 :agree: It is always good practice to change all rotating part when doing a clutch job, because the cost & down time it take to split the motor & tranny. Flywheel, pressure plate, clutch disc, pilot bearing & threw out bearing, aka release bearing, aka slave cylinder, in GM's case threw out bearing & slave cylinder is all in one unit.
I now it suck, my $100 threw out bearing in my Legacy GT is making noise. So this weekend that $100 failing part is costing me another $450 in parts to complete this clutch job. It has 100k on the last clutch job & it's not slipping towing a 3k lbs. car.
Mike
« Last Edit: September 03, 2011, 09:14:59 AM by HAMMER DOWN »
« Reply #294 on: September 03, 2011, 09:06:44 AM »
Mister Bond.  Tip... before you install the LEDs, a number of us have found that the gas-gauge LEDs are too bright compared to the others.  It's advisable to add a resistor in line with the power leads.  I'm afraid I forget what value I used, but something in the order of 200 ohms should work. (Check the brightness before you put the needles back on & console back together.)
Also see these steps for how to set the needles correctly: http://www.solsticeforum.com/forum/f59/want-change-mph-cluster-kph-68945/#post1049883
« Reply #295 on: September 05, 2011, 06:58:42 PM »
After polishing the factory driver-side IC charge pipe well over a year ago, I finally got round to doing the passenger side today.  Took a lot of wet-sanding and polishing to get most of the tool-marks out.  I didn't want to go too deep and I concentrated on the areas that are visible when it's mounted, but it came out pretty nicely I think.  Before and after photos:
[attach=1]
« Reply #296 on: September 06, 2011, 12:21:58 AM »
Mike
So you saw where I ordered the Clutch kit from Spec with a Flywheel.  Do you (or anyone) have part numbers for the other items that I should replace?
Offline J_Bond
« Reply #297 on: September 06, 2011, 01:18:14 AM »
Thank you very much for the tip!   I appreciate it!   :thumbs:
SOLO header
SOLO High Flow Cat
Koni shocks
Pro-Kit springs
Hawk Ceramic pads
Redline headlights
Gutted trunk
« Reply #298 on: September 06, 2011, 02:53:44 AM »
[attach=1]
Nice work TS !! looks far better after the polishing!
strange....i haven't noticed the part attached to the pipe in the foto, in my car's engine bay.... what is it use for?
Offline HAMMER DOWN
« Reply #299 on: September 06, 2011, 03:15:51 AM »
Sorry, I haven't done a clutch job in are Kappa yet, but you could PM  snaponbob, he done it already.
 http://www.kappaperformance.com/forum/index.php/topic,7076.0.html
Mike
