As I said above, there's no existing amp harness. I had to wire my own power, speaker wires etc. I used an Eclipse 4 channel amp in the stock amp position (behind the driver seat) and an OEM speaker box off eBay, but with a Kicker 8" sub mounted in place of the OEM sub. I ran two amp channels to the front speakers and then ran the other two to the sub. I don't use the rear 3/4 panel speakers, and don't miss them.
At the radio end, I had an aftermarket harness I originally used for a Bluetooth retrofit... basically a pair of plugs that go into the radio which are wire-for-wired into a pair of sockets that the old (OEM) radio plugs connect to. I spliced into these harness wires for the amp connections and didn't mess with the original factor harness. However, this is not necessary and you could just splice into the factory wiring instead.
