Author Topic: wheel weight  (Read 10389 times)
Offline bluegxp
wheel weight
« on: September 18, 2011, 11:32:06 AM »
Anyone know the weight of the stock 08 GXP wheel?
2008 GXP (stock)
Re: wheel weight
« Reply #1 on: September 18, 2011, 12:04:21 PM »
25 pounds give or take.  Depends on which wheel.
Re: wheel weight
« Reply #2 on: September 18, 2011, 12:18:17 PM »
check this ----------->          http://www.solsticeforum.com/forum/102892-post6.html
Re: wheel weight
« Reply #3 on: September 18, 2011, 12:21:50 PM »
 GJ  :   You were just about right on  Good call  ,Even if it was a Guess    :D   :thumbs:
Offline bluegxp
Re: wheel weight
« Reply #4 on: September 18, 2011, 09:52:16 PM »
Thanks gents.  My GXP has the 5 spoke chrome wheels.......@ 24.6 pounds each.  I think some new wheels are in my future:
http://www.tirerack.com/wheels/MiniWheelSearchServlet?nonWinter=true&partNum=4608805140BS&autoMake=Pontiac&autoModel=Solstice&autoYear=2008&autoModClar=GXP&wIndex=16&grid=true&sw=1536
At 18.6 pounds each.
2008 GXP (stock)
Offline J_Bond
Re: wheel weight
« Reply #5 on: September 18, 2011, 11:15:41 PM »
stock sky wheel weighed in at a hefty 26lbs in chrome for me.  stock tires are heavy too, about 27lbs each.  go with a Conti DWS tire, it's about 4lbs lighter!
WERKS lightweight battery
Dyno-tuned ECM by HP-Tuners
SOLO Single Catback exhaust
SOLO header
SOLO High Flow Cat
Energy suspension bushings
Koni shocks
Pro-Kit springs
EBC slotted dimpled rotors
Hawk Ceramic pads
BLACKED-out everything...
Redline headlights
Gutted trunk
Offline J_Bond
Re: wheel weight
« Reply #6 on: September 19, 2011, 10:02:02 AM »
actually, wheel-weight is VERY drive-train relevant!!!  we're discussing rotating mass
SOLO header
SOLO High Flow Cat
Koni shocks
Pro-Kit springs
Hawk Ceramic pads
Redline headlights
Gutted trunk
Offline bluegxp
Re: wheel weight
« Reply #7 on: September 20, 2011, 08:58:08 AM »
rotating mass......the less of it the quicker the acceleration.
2008 GXP (stock)
Offline bluegxp
Re: wheel weight
« Reply #8 on: September 20, 2011, 09:04:29 AM »
I bought my gxp used, but it has new tires.....Riken Raptors ZR.
2008 GXP (stock)
Re: wheel weight
« Reply #9 on: September 20, 2011, 09:11:44 AM »
Yep, see this post.
http://www.kappaperformance.com/forum/index.php/topic,6095.0.html
Offline bluegxp
Re: wheel weight
« Reply #10 on: September 20, 2011, 10:50:18 AM »
Thanks Sly Bob.....good reading in that link.
Anyone have comments, good or bad, concerning Enkei Racing PF01 wheels?
Also, can someone comment on proper wheel balancing; placement of wheel weights.
« Last Edit: September 20, 2011, 10:53:53 AM by bluegxp »
2008 GXP (stock)
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: wheel weight
« Reply #11 on: September 20, 2011, 11:50:07 AM »
Hey, I didn't know they made PF01s in our bolt pattern, that's great!  The et40 should be about perfect for me as well  (like a knock-off of my favorite wheels, Work Emotion CR KAI)  -- keep in mind that wheel would sit 15mm further out than the stock.
Enkei is a decent brand for cast wheels and 18.6 lbs is fantastic but sacrifices strength (watch out for large pot holes) since they are not forged.
 I've also been looking at TeamDynamics since they can build for any PCD with multiple offsets: http://www.teamdynamicsracing.com/pro-race/Pro-race12.htm
and similarly Forgestar will too  http://www.forgestar.com/v2/wheelsf14.php
Outside of this realm, you'd be spending 2-4k for a set of forged wheels in our bolt pattern and an aggressive offset.  Say at CCW http://www.ccwheel.com/wheelprofiles-display.php?id=Classic
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: wheel weight
« Reply #12 on: September 20, 2011, 01:35:24 PM »
Man, this really got me thinking about splurging on wheels again.
I'd love some super-concave Forgestar F14s and it looks like if you can get 15+ people, the price drops down to around a grand for 18" barrels:
http://www.e46fanatics.com/forum/showthread.php?t=732971
edit:  mmmmmmm
« Last Edit: September 20, 2011, 02:08:21 PM by idkfa »
Re: wheel weight
« Reply #13 on: September 20, 2011, 02:31:47 PM »
Kelu has Team Dynamics.
My Wife has them on her mini.  They are much easier to clean than my OZs. but are close to 2lbs heavier.
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: wheel weight
« Reply #14 on: September 20, 2011, 02:50:38 PM »
Yeah, i hear they are big in the mini groups.  What size/weight are your OZs?
Re: wheel weight
« Reply #15 on: September 20, 2011, 02:58:13 PM »
I have 18x8s
I believe they are 18.6 lbs
Re: wheel weight
« Reply #16 on: September 20, 2011, 03:01:23 PM »
Just checked
Team Dynamic 18x8 are 19.8lbs
Re: wheel weight
« Reply #17 on: September 20, 2011, 03:54:46 PM »
elff: is right, the weight of Team Dynamics for 18x8 are 19.8 lbs which same as Oz Ultraleggera but way cheaper around here, I would recommend them if would be the case.
Around here, owners of TD say that they are much stronger than Oz and they are right, Romanian roads are deadly for rims in general because we had very bad roads, I know another 2 TD owners (Opel and Mini) and had 0 issues in about 3-4 years with them which I can't say about Oz.
TD around here costs around $1000-1300 compared with $1500-2000 for Oz.
Here are some pics ;)
« Last Edit: September 20, 2011, 03:59:53 PM by Kelu »
Re: wheel weight
« Reply #18 on: September 20, 2011, 04:29:29 PM »
I think the added strength is due to the design of the spokes.  They are thicker and spread out evenly across the entire circumference.
The OZs are multiple pairs.
I am still considering getting some 18x9s with 265s all the way around.
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: wheel weight
« Reply #19 on: September 20, 2011, 08:14:02 PM »
Love your fitment, Kelu. 18x8s? What's your offset?  I also agree about the spokes... I'm still kinda worried about our roads with my SSR Cs.  They're not bad but are known to yield to some pressure.
Have we revisted those offset threads now that more affordable custom wheels are available for our PCD?  It was cute in all the old wheel threads when all that was available were horrible knock-offs with stock offset.  Widest 18s with a more aggressive fit :)
Re: wheel weight
« Reply #20 on: September 21, 2011, 04:05:10 AM »
The spokes play a good role in strength but the potholes from roads around here are destroying mostly the tire lip on a rim.
My rims are 45 offset on 18x8, I remember I could order what I prefer 45-48 offset, the rims being produced based on order but it took about 2 months delivery to my door from UK.
« Last Edit: September 21, 2011, 04:13:53 AM by Kelu »
