Author Topic: Water Pump FAILED, Right Motor Mount NOT BAD  (Read 26723 times)
Re: Water Pump FIXED (sort of) Right Motor Mount FAILED
« Reply #25 on: October 03, 2011, 04:02:40 PM »
If the bolts are tight there should not be any movement of the LVKFCB.
« Reply #26 on: October 03, 2011, 04:11:21 PM »
LV, i am not talking about any movement, i am talking about POSSIBLE noise that comes from the brace being stressed when the body tends to flex and it rubs against the frame.
once again, i am NOT saying any bad comment for the product, i really like it!! all i am saying is that it may be making a minor noise (metal rubbing on metal) when stressed on the case i described. if what i have noticed is related to the LVFB, it actually indicates it really works
« Reply #27 on: October 03, 2011, 04:31:12 PM »
Made it the 1000 miles to DDM and guess what... the water pump let go. Getting replaced tomorrow morning at the local Chevy dealership.  The shudder in my rear is a mystery to everyone (including Dave).  Just waiting for something to give.
The LV Brace is back in but the Probeam is out. For troubleshooting.
Tomorrow is a new water pump, steel brake lines, stage 3 clutch, and center console.
The folks here at DDM have been wonderful as always and I only wish I had more time to spend here.
Re: Re: Water Pump FIXED (sort of) Right Motor Mount FAILED
« Reply #28 on: October 03, 2011, 07:42:34 PM »
Out of curiosity, what did the noise sound like.  I have a noise that sounds like its coming from the front right of the car.  It happens when I go over road abnormalities.  It sounds just compressing the springs on an old mattress.  I have had the car on my dads lift 3 times already and they have pulled on the suspension really hard and all over and the sound happens when three of them pull on the front sway bar.  The sway bar is tight and they checked everything around it.  Could that be the motor mount as well?
Is your alignment stock? When mine got a performance alignment at the Mod Meet I started hearing that sound going over big dips. I think changing the camber may be creating more movement in the suspension. I will hit the sway bars with wd40 when I change to winter tires.
Re: Water Pump FAILED, Right Motor Mount NOT BAD
« Reply #29 on: October 03, 2011, 09:06:45 PM »
Don't use the WD-40.  It's not good for the bushings.  Use a silicone grease.  And if it is your sway bars, simply spraying them won't do much.  However, all you need to do is remove 4 bolts on the bushing brackets, and then you can apply a paste silicone grease on the inside of the bushing, and I personally have tried it, and it works, and lasts (2 years ish now without a squeak, when it was brutal the first winter my car saw).
Offline diamoney
« Reply #30 on: October 03, 2011, 09:23:06 PM »
Made it the 1000 miles to DDM and guess what... the water pump let go. Getting replaced tomorrow morning at the local Chevy dealership. The folks here at DDM have been wonderful as always and I only wish I had more time to spend here.
My w/pump did the same and against advice of several (w/ blessing of others) I basically dod not lose coolant for over a year after initial leaks.  Then came Nats in Austin- Dave and Randy did the work!  Always thankful for them...
#000600 S/C
158000+ miles
'07 GXP T/C+
0-100 in what?
« Reply #31 on: October 03, 2011, 09:31:44 PM »
I am told that WD40 is working well for some of us with a bit of mileage on their cars.
« Reply #32 on: October 04, 2011, 12:34:20 AM »
GJ what else could he possibly mean with that statement?  It just sounds kind of creepy to me.
« Reply #33 on: October 04, 2011, 08:44:56 AM »
Well he is a submarine sailor that spends months underwater with other men.
« Reply #34 on: October 04, 2011, 09:02:58 AM »
We checked the LV brace and it was super tight...I have had the brace on for a little while and the sound is new.  DDM did an alignment for me at the last meet.  It sounds like when you jump on an old mattress (the springs being old).
« Reply #35 on: October 04, 2011, 09:11:28 AM »
Thats my sound. Appeared after alignment, before LV brace.
« Reply #36 on: October 04, 2011, 09:13:55 AM »
arabas vs LV = 0-1 :)
as i said it was a thought, really enjoy the benefits of LVFB.
hmmm...both got this after alignment?
« Reply #37 on: October 04, 2011, 10:31:02 AM »
Notice how WD stands for water displacement?  WD-40 is good for displacing water, but over time, it does not last as long as a paste grease, mostly because it is delivered with a solvent, which evaporates over time.  Furthermore, because it is petroleum based, and with the addition of the solvents, WD-40 should never be used on rubber/polyurethane parts.
So it does help with squeaks, but does not last long, and will damage the rubber/polyurethane bushings.
« Reply #38 on: October 04, 2011, 03:38:50 PM »
From WD-40s web site (http://www.wd40.com/faqs/#a98):
What surfaces or materials are OK to use WD-40 on?
WD-40 can be used on just about everything. It is safe for metal, rubber, wood and plastic. WD-40 can be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40.
« Reply #39 on: October 04, 2011, 04:47:15 PM »
Water pump has been replaced and is now cooling better than ever.  Off to DDM for steel brake lines and Stage 3 clutch installation.
Offline ChiliSky
« Reply #40 on: October 04, 2011, 05:52:17 PM »
Great to see you today..glad the Water Pump is fixed ....you will be a happy camper going back through the mountains tomorrow, I am leaving around 6am, heading up I-26 to Bristol and then on to I-77....if I see white fly by me I'll know it's you!!!!safe travels to you.
« Reply #41 on: October 04, 2011, 06:19:50 PM »
Think about it, if it can't be used on polycarbonate and clear polystyrene plastic, it's because it contains a solvent that will harm them.  Until that solvent entirely evaporates, it will be doing harm to the surface it is on.  You can tell when that happens because it will stop smelling of WD-40.  So if you can still smell it on the surface, the solvent is still there.  And it is most noticeable on polycarbonate and clear polystyrene, because they are typically clear and you can see the damage readily.  If there were clear rubber, you'd see the same damage. Damage that is caused by the solvents.
But hey, keep using WD-40 on polyurethane and rubber all you like.  It's your bushings it's damaging.  Sorry for trying to prevent people from using it in a manner that will degrade their bushings. :banghead:
And even if it were 100% safe on rubber and polyurethane.  Why bother using it?  Almost every time people use WD-40 to quiet down bushing squeak it always returns shortly afterwards (within a year).  Why not do it right, and use the right grease (silicone), applied properly (as a paste, with the bushing removed from the car) and never have to worry about it again?
« Last Edit: October 04, 2011, 06:56:59 PM by Carbon Sky »
« Reply #42 on: October 04, 2011, 06:50:05 PM »
Glad you got the water pump issue resolved, Jeremy.
Offline ophidia31
« Reply #43 on: May 11, 2012, 06:52:37 PM »
Chalk me up for something crazy with the water pump. First story, where I park my car, water usually pools a little bit after raining under the front driver side and a little past the front bumper. So, that in mind, it rained a little bit earlier in the day so I didnt think anything of the wet pavement when i came out to my car wednesday night. Get in, start it up, low coolant message. ::insert expletive here:: Turn it off, pop the hood and check the overflow and its down to where CT said his was. Run my finger through the spot on the ground, already knowing what it is. Yep, that weird residue feeling when it dries up.  ::insert more expletives:: Run my hand along the bottom of the radiator. Nothing. Go and check out the water pump area fearing the worst. And you can see where it ran down the back, onto the lower frame crossing and onto the ground. Get the flashlight app out on my phone to look further under and hiding in the little pocket in the casting is a nice pool of coolant flipping me off. Well, nothing I can do here since it seemed to have stopped, so closed the hood, turned the heat on full blast and took it gingerly home watching the temp readout like a hawk. Didnt get above 210 degrees but got there abnormally quick.
The next day (yesterday) was lucky as I was off from work. Let it sit over night into thursday and checked the level in the morning and was at the same spot as before. Looked under the car, no drops or puddles. Called up the dealership and was able to bring it in today since theyd have a loaner car for me. Got a call from the service desk lady saying theyd need to have it until monday. I didnt think to ask what they found out as I was in the middle of working on a car at work. So the waiting game begins and we'll see whats up then.
2013 Grigio Abarth 500
« Reply #44 on: May 11, 2012, 08:24:57 PM »
I just had mine replaced on Wednesday. The first one didn't work so they replaced it again. Now it's running great. No major concerns :)
Good luck!
I used Tapatalk Elff!
« Reply #45 on: May 12, 2012, 12:14:51 AM »
Make sure they know about the timing chain!  It's worth at least calling them or emailing the procedure.  Check with DBG'S for a print out.
Offline ophidia31
« Reply #46 on: May 12, 2012, 12:35:25 PM »
Not too worried about it. The guys at this dealership seem to know what theyre doing and the guy who worked on my diff issue worked at the saturn dealership so hes worked on kappas before. Did a quick read through for water pump replacment and it clearly states using the j-blah blah blah tool to lock everything in place. Looking through dbgs thread, it seems he might have gotten someone who just didnt give a crap about it and just doing it to get it done. Also, if there is any noise that wasnt there before, they already know that I am going to be back about it and the ex-saturn worker knows i know the car inside and out as I had a good conversation on the one ride along.
« Reply #47 on: May 12, 2012, 05:29:18 PM »
I replaced the water pump on my jeep and the wife had to replace the one in the mini.
Seems like no cars have a good design for this part
Offline HAMMER DOWN
« Reply #48 on: May 13, 2012, 01:19:49 AM »
 :idk:  about that. My 05 Subaru Legacy GT, as over 194k on original water pump, motor & turbo. It's at stage 2+, best 1/4 mile, 13.65 @ almost 101mph. And swap in 05 STi 6MT back in 07.
My Sol. GXP as over 75K on the original water pump.
Mike
« Reply #49 on: May 13, 2012, 09:29:32 AM »
But is that an exception or a norm?
With the weird design of the subaru engine, is a water pump a piece of cake or a nightmare?
It's either got to be buried or completely exposed.    It's proven itself to be an awesome engine, but I really would like to know the inventors thought process. Its so different than everything else
