Some time ago someone at ZZP told me they had been working on modifying the OEM HPFP but the results were not sufficient to move forward with it. That said, it makes sense. If the pump body is "opened up" to flow more, there must be a method for more to actually flow. THAT seems to boil down to either MORE strokes per cam revolution, or LONGER stokes. Absent one of both, the rail apparently can empty faster than the pump can meet demand.
BTW, as for the in tank pump, there may be a different, or at least additional flow issue. There are two methods for the pump to grab fuel - either it pours over the top of the bucket that it sets in, or come up from a small (and I mean small) rubber one way (passive) diaphragm. When I ran straight gas, I could run Solo laps almost empty. With E85 I had to run 3/4 full, and with E60 I continued to do so. I'll try it "low" at the upcoming T&T and Solo events at the end of the month. (You can be certain I will have more gas and E85 with me as well to fill 'er up.)
