If the lights are off try the POST (power on self test). The lamps should light for a couple secs when the ignition is switched on, then go out. If this is the case, then go for a drive over 25 MPH, if the lights stay out then the ABS is up and ready. I would not seek repairs if the POST runs and the lights stay out. You could wait for some rough or wet pavement to test the system too. By any chance were the lights on for just one ignition cycle?
Clear Skies!
Scanner - My car is currently my daily driver. The lights were on for a couple of ignition cycles that's why I became concerned. Probably about 4-5. They haven't come on since my brother cleared it.
I wasn't sure how to do the POST test so I called GJ and he said to take 4 D batteries... He confirmed I am doing it correctly.
All the lights light up and then the only ones that stay on are engine, brake, oil & seatbelt.
I have started it for about 4 cycles today and the lights have not reappeared. I'll find some rough pavement tomorrow (we have plenty of that around here) and see if the ABS kicks in.
P.S. TS - You thought our cars were tough to lift, for the Porsche GT you have to put ramps together before you can even drive it onto the lift. The Carrera GT there are ramps, then laminate plates, then straps, etc. He tells me the Carrera GT is a 2 hour process before you can even lift it.
