When you get some time, let me know if its a tial 38mm, 44mm or 60mm. I have been debating on which of these to get for my car, and im curious if the 44 is enough flow to keep the turbo from creeping up/ having large boost spikes
my 38mm tial wg had no issues controlling 28psi of gt3582r.
but I'm not sure what build you are trying to do.....
I still think that 38 or 44mm wg, will be more than adequate.
60mm will be just overkill.
anyways...hope this helps (taken from wikipedia):
Wastegate sizing is inversely proportionate to the desired level of boost and is somewhat independent of the size or power of the engine. One vendor's guide for wastegate sizing is as follows:[3]
big turbo/low boost = bigger wastegate
big turbo/high boost = smaller wastegate
small turbo/low boost = bigger wastegate
small turbo/high boost = smaller wastegate
However, exhaust flow is an effect of power. So, another decision chart should look like this.
big turbo/small engine/small power = small wastegate
big turbo/big engine/ small power = medium wastegate
big turbo/small engine/big power = big wastegate
small turbo/small engine/small power = small wastegate
small turbo/big engine/any power level = big wastegate -->The reason for this is that the small turbine will easily try to overspin from excess exhaus gas volume.
