Author Topic: BSS-brake warp again! Are you F'n kidding me?  (Read 14566 times)
Re: BSS-brake warp again! Are you F'n kidding me?
« Reply #25 on: March 01, 2012, 09:35:21 PM »
So you don't "drive it like ya stole it?"
« Reply #26 on: March 02, 2012, 01:29:18 AM »
When you steal a car, you tend not to use the brakes much....
Offline IBDRINKEN
  • Donkey Master
« Reply #27 on: March 03, 2012, 02:31:49 AM »
I was the running the Porterfields and stainless steel brake lines and had alot of stop and go traffic. They performed excellent.
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
Offline diamoney
« Reply #28 on: March 04, 2012, 09:52:11 PM »
I read something recently from Brembo that goes against the common knowledge of brake issues-
They stated that rotors rarely warp!  That was followed with, the pulsing feel is almost always caused by a build up of crud on the brake pad.
If this is so, the condition of your RF brake sounds like:
sticking caliper causing excess heat;
heat resulting in breakdown of pad matrix, creating thick/thin areas on the pad surface;
culminating in a pulsing pedal feel.
For what its worth!
#000600 S/C
158000+ miles
'07 GXP T/C+
0-100 in what?
Offline diamoney
« Reply #29 on: March 07, 2012, 12:27:38 AM »
Funny cause when you look at the rotor, thats what it looks like too.
Sorry, BSS, but are you saying the rotor does look warped or does not look warped?
#000600 S/C
158000+ miles
'07 GXP T/C+
0-100 in what?
Offline IBDRINKEN
  • Donkey Master
« Reply #30 on: March 07, 2012, 06:46:48 AM »
I sold my car to a buddy of mine and they are still on the car
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #31 on: March 07, 2012, 07:25:04 PM »
No SA I didn't type that for BBS
Offline JimmyBaja
« Reply #32 on: March 07, 2012, 08:13:23 PM »
¿Sure your are
« Last Edit: March 08, 2012, 08:36:25 AM by JimmyBaja »
« Reply #33 on: March 07, 2012, 08:49:39 PM »
Would you mind helping him out, I can usually decode what you miss type.
Offline HAMMER DOWN
« Reply #34 on: March 10, 2012, 02:22:27 PM »
BSS if you have access  to infrared temperature gun. You can tell if & what caliper is hanging up. It what I use when I had the same problem with my Subaru Legacy GT. I had 114k on the original calipers & rotors.  Took the car for drive, with a lot of stops. Take temp of rotors & calipers.  The rears was under 300F an with in 20F of each other. The front DS was of the chart (I.F. Gun max out at 600F) PS was over 500F. I found out that both bottom front caliper pistons was seized. Replace Calipers, rotors, & pads, problem solved.
Mike
« Reply #35 on: March 21, 2012, 03:00:31 PM »
I am putting a high percentage on it being just your pads.
Go throw the proper bedding procedures with the new ones and go from there
