Author Topic: 2nd Gear Synchro bad??  (Read 2713 times)
Offline hammy221
« on: April 14, 2012, 08:37:38 PM »
so i was on my way home from work and just all a sudden couldent seam to get the car in 2nd without grinding. afterrelizing that it only did it in 2nd and once its in it stays in no problem i think its the 2nd Gear Synchro. anone on here ever have that issue? also anyone ever replace them if so how involved is it?
Re: 2nd Gear Synchro bad??
« Reply #1 on: April 14, 2012, 08:49:53 PM »
i had the same issue a couple of years ago.
But I still drove my car and just skip the 2nd gear.  I go from 1st to 3rd gear for about a month.   Then the 3rd gear started grinding as well..
We opened up the tranny, and discovered lots of metal shavings when we drained the oil.
I ended up buying a new tranny.
I believe one guy from solstice forum, had the same issue.    http://www.solsticeforum.com/forum/f43/2nd-gear-synchro-pics-71831/
he will try those stronger Carbon Fiber lined synchros from AR5 hummer H3
not really sure if it will be compatible tho.......
Offline hammy221
« Reply #2 on: April 14, 2012, 09:02:29 PM »
ahh ok was it just the syncro gears bad when you got into there? im debating on weather to buy a new one swap them then fix the old one and sell it or tear it out and fix it all toghter
Offline hammy221
« Reply #3 on: April 14, 2012, 10:24:14 PM »
also has anyone gotten a warranty on something like this even after a supercharger add on? id think they might do it as i dont belive extra power would cause it to fail
« Reply #4 on: April 15, 2012, 06:27:34 PM »
Hammy221.
Here is a link to the BB where there is a thread about what you are trying to do.
