Author Topic: Speed density tuning no MAff needed  (Read 24169 times)
Re: Speed density tuning no MAff needed
« Reply #25 on: June 10, 2012, 03:52:35 PM »
There's a lot of ego in this thread too.  Good grief.
For the record, I can piss 3 feet, 4 and 1/4 inches.  That was measured on a warm night, so median air density had some effect on the contest results.  I did not use a MAF during my pissing contest.  My IAT was 98.8 and I was using all stock components.
My tuners name shall remain a secret as I don't really want any of you using the same tuner as me.
Re: Re: Speed density tuning no MAff needed
« Reply #26 on: June 10, 2012, 04:26:36 PM »
Before or after partaking in some beer?
Offline |V3nom|
« Reply #27 on: June 12, 2012, 05:41:09 PM »
lol good stuff and good point.
08 Bluestone RL Manual
Wester's Race Tune
Solo Street Race with Two Magnaflow 5" Round Mufflers
8K HIDs Lows and Fogs
Lil Chromies
JPM Piston Shifter and Boot Cover
JPM Seat Belt Holders
« Reply #28 on: June 14, 2012, 04:39:17 PM »
I have heard that if you are at an elevated height that you can get more range because you are taking advantage of the lower air density at the higher elevation, not to mention the change in the "power curve," you should ask your tuner if that is true of just BS.  Even if it's not true all we have to do is get enough people on the internet to say it is and then the laws of nature have to comply with it, take that mother nature, :censor: .
Offline Ames Performance Tuning
    • Ames Performance Tuning - Trifecta Dealer
« Reply #29 on: June 20, 2012, 05:37:10 PM »
GJ,
I am jealous.  Over the last 5 years, I would be lucky to make it 2 ft regardless of air density and humidity.  You must be living right!
Just some additional info to bring out the egos again.  Some other car companies use this form of tuning safely, for example the Hyundai Sonata with 2.0 Turbo.  GM does provide the necessary information in the ecm to adjust fuel safely without using MAF.  I do plan on testing this feature soon while monitoring A/F and knock.  I am a "show me" kind of person.  Current testing, tune has been spot on.  The benefit as listed earlier will allow easier tuning flexibility for a variety of intakes and BOV's.  This will help create less expensive tuning products for folks with intake mods.
09 GXP Coupe Auto - Stock Trifecta EBlend tune
09 GXP Coupe Manual = Trifecta EBlend tune
DDMWorks rebuild with Carrillo rods, Wiseco pistons and ported head and 2860
Solo HF Cat and Mach Shorty
Probeam, Backbone and Eibach Pro
Dunlop Dirreza *Spec
1987 Buick Grand National
1978 Trans Am
Trifecta Dealer
http://www.amesperformancetuning.com/Solstice.html
Offline 40rtyp
« Reply #30 on: June 20, 2012, 07:01:09 PM »
^^^ You going to post results???
« Reply #31 on: June 20, 2012, 07:17:51 PM »
When fuse #43 was not seated properly I was running in Speed density mode and it was OK but cold starts were a bit rough.  Though I think Dave said #43 also powers the O2 sensors it fail those also I would assume and why it was reading 1 lambda when it was commanding .85 lambda under stock boost of 17 Psi Other than that my engine didnot go boom or knock.[attachimg=1]
« Last Edit: June 20, 2012, 07:31:52 PM by tazz »
« Reply #32 on: June 20, 2012, 11:20:32 PM »
I will post results when I get the tune to test.  I assume you are not talking about the results of me trying to pi$$ as far as GJ.
1978 Trans Am
Trifecta Dealer
Offline 40rtyp
« Reply #33 on: June 21, 2012, 01:25:51 AM »
You are assuming correctly there guy.
« Reply #34 on: June 21, 2012, 05:21:55 AM »
I would like both results please
Offline JoshMcMadMac
« Reply #35 on: June 21, 2012, 10:28:33 AM »
How so?
« Reply #36 on: June 21, 2012, 11:56:56 AM »
LOL - Video - I guess.  Seriously, I will work with some logging before and after while looking on some different days based on temperature and humidity.  I will change intake etc. and ensure I validate the current testing.  Another test car is running fine with an just an air filter attached to turbo while using aftermarket BOV.
1978 Trans Am
Trifecta Dealer
« Reply #37 on: July 04, 2012, 02:40:59 PM »
To finish out this thread, we did tune my Manual Coupe it ran good and the logs were as expected.  This is an option we can use with aftermarket BOV's and other intakes that prove troublesome to tune.
1978 Trans Am
Trifecta Dealer
Offline 40rtyp
« Reply #38 on: July 04, 2012, 04:08:25 PM »
No Logs of giving us some information on this Mafless tune? How can you prove that it's an actual viable option?
« Reply #39 on: July 05, 2012, 12:09:38 AM »
There really is not any way I can prove it that someone could not say something like those are not really the logs or look at that metric or whatever.
All I am saying is my car ran fine.  I did not see any KR that I was worried about.  The metrics I knew to review where fine in my limited log.  When the more detailed logs where reviewed by Trifecta they were okay.   I know there is a group of folks that will not believe the results and that is fine.  This info is for the folks that already trust the product.
I apologize for setting the expectation that I would provide logs.  The Trifecta logs are proprietary and the logs I created may not be as relevant.  Anyway, folks with a MAF can still have their tune as normal with stock BOV for example.  This feature is for folks with the aftermarket BOV and intake that can't currently tune their cars well with these parts.
1978 Trans Am
Trifecta Dealer
Offline 40rtyp
« Reply #40 on: July 05, 2012, 12:33:36 AM »
Roger
« Reply #41 on: July 21, 2012, 09:01:37 PM »
Apparently a member on HPT has been able to basically run SD by disconnecting and failing his MAF almost like I mentioned above and adjusting some other parameters to make it run smoother.  I could not see why it would not work since the SD tuning is already in the stock ECM as a backup if the MAF failed.
http://www.hptuners.com/forum/showthread.php?t=39910
Offline BNRacing
    • Bad News Racing
« Reply #42 on: August 13, 2012, 10:34:12 AM »
I helped develop this new tuning and it is NOT speed density. You still need the MAF to be hooked up so it can ready humidity, IAT, etc. Yes disconnecting and zeroing out the MAF will force the ECM to run off the SD tables, but that's not what we're doing.
« Last Edit: August 13, 2012, 10:38:24 AM by BNRacing »
-Jerry
Owner
Bad News Racing
www.badnewsracing.net
