Author Topic: 9.5 wheel offset/fitment question  (Read 19503 times)
Offline ebrown0104
« on: June 22, 2012, 12:44:27 PM »
So, I think I found a set of wheels I want to go with on my Solstice... TSW Carthage:
They are Mercedes fitment 5x112, but I found a set of wobble nuts that will allow them to fit.  So, I was planning on running an 8" front wheel with +45 offset and 245's which will fit fine.  On the back I wanted to go with a 9.5" wheel with a +53 offset and 275's, which would move the outside out 21mm and the inside lip would be 17mm closer to the inside of the car.  So, basically I wanted to see if they would actually fit without hitting anything.  I tried doing a quick measurement and it looks like the fronts would be flush with the fenders, the rears will stick out a little bit, and I should have enough clearance inside the rear wheelwell to fit.  But, I figured I would ask the all-knowing experts of this forum just to be sure.
Also, another question: Has anyone ever done 18's on the front and 19's on the rear, a la Corvette?
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
Re: 9.5 wheel offset/fitment question
« Reply #1 on: June 22, 2012, 01:02:05 PM »
Link to the PCD Variation nuts?  Are you converting over to a different stud?
« Reply #2 on: June 22, 2012, 01:02:20 PM »
As far as I know our stock wheels fit to 5x112 bolts so 5x112 wheels should fit also on out 5x110 fitment.
I loved the rims ;)
« Reply #3 on: June 22, 2012, 02:33:04 PM »
Those with "square set up" want to go "staggered" and those with "staggered" want to go "square".
Grass is always indeed greener on the other side.
Offline shabby
« Reply #4 on: June 22, 2012, 02:35:48 PM »
Here's a 275 tire on a 18x9 with a +55 offset, i needed to add a 5mm spacer to get rid of the tire rubbing the frame on the inside.
I also added a bit more camber since i took that pic and rolled the fenders, the tire will be rubbing the plastic fender piece if you're lowered but that's no big deal.
Offline ebrown0104
« Reply #5 on: June 22, 2012, 04:50:21 PM »
http://www.tulipcitywheels.com/tcwstore/index.php?l=product_detail&p=1730 link for the nuts.  I haven't checked yet but I'm assuming that Kappas use 12x1.5 thread like pretty much every other GM out there.
I'm doing the staggered wheel look purely for looks.  I know it's going to affect the handling a little bit, but my car will never be on a racetrack so I don't think I'll notice the difference.
« Reply #6 on: June 22, 2012, 06:44:24 PM »
Shabby, I'd love to see the photo of the rolled fenders
« Reply #7 on: June 25, 2012, 08:21:56 AM »
I'd like to see a 19/21 set-up.  Was thinking of 20/22, but seems like most folks who go with 22s going back to originals because the ride becomes to hard.    Remember reading somewhere that a little know fact is the tire sidewalls acts or is considered part of the suspension.
BTW, those are some classy looking wheels.
« Reply #8 on: June 25, 2012, 01:50:37 PM »
I have OZ 18x9 Rear Rims with 275s and am only rubbing the wheel liner.  I have no frame contact.   The rim is really close to the upper A-Arm though.  I wonder if that will be an issue with those rims.
As far as the handling goes, it has had zero negative effect on handling.  I don't know why people say or think that.  As long as the alignment is correct, it's a non issue.  There are tons of cars running staggered setups.
« Reply #9 on: June 25, 2012, 01:54:21 PM »
What is your ofset Elff?
« Reply #10 on: June 25, 2012, 01:56:36 PM »
Same as Shabby.  From the picture he posted, I'd venture we have the same rims.  Oz Ultraleggera 18x9s
« Reply #11 on: June 25, 2012, 01:57:28 PM »
You couldn't just say +55, you had to make me go look didn't you.
« Reply #12 on: June 25, 2012, 01:59:47 PM »
:yay: :yay: :yay: :yay: :yay: :yay: :yay: :yay: :yay: :yay: :yay:
 :lol: :lol: :lol: :lol:
Offline ebrown0104
« Reply #13 on: September 27, 2012, 06:22:23 PM »
OK, I've been doing some research, how does everyone feel about these wheels:
They are from an Opel, I photoshopped them onto my car to see how they look.  I like them.
« Reply #14 on: September 27, 2012, 06:29:28 PM »
I like those wheels but I'm wondering what they weigh?
Offline Brazen17
« Reply #15 on: September 27, 2012, 06:47:11 PM »
Not a bad looking wheel but not sure it fits the solstice lines... I liked the wheels in your original post much better!
Offline Rogue
« Reply #16 on: September 28, 2012, 08:53:14 PM »
The issue with wheel offset is more about centering the wheel load over the centerline of the hub bearings. If you move the wheel too far off the hub centerline you then have the inner or outer hub bearings carrying the greater forces. This will adversely effect the life of the bearing assembly and may cause some instability issues.
Go N.A.K.3.D..
« Reply #17 on: September 29, 2012, 03:49:05 AM »
I loved the rims ;)
Can anyone else confirm/deny this staement?  Kelu, can you clarify or point to a source?  I've been dreaming of Lorinser LM6 wheels for awhile now, but always worried about using wobble nuts and/or having to re-drill 5x112 wheels for a 5x110 bolt circle.
« Reply #18 on: September 29, 2012, 06:35:43 AM »
All I can say for sure, my stock wheels went on an Audi which is 5x112. The guy drove them a lot so no issues over time also.
Offline shabby
« Reply #19 on: September 29, 2012, 09:54:31 AM »
That may be so but the lug nut still isn't making perfect contact with the wheel since its sitting 1-2mm to the side depending how evenly the lug nuts are torqued down, unless the stud is bending when its torqued, who knows but its not ideal.
« Last Edit: September 29, 2012, 09:57:54 AM by shabby »
Offline GXP_Matt
« Reply #20 on: October 01, 2012, 11:39:10 AM »
If the rear wheel+tire diameter is larger than the front it's going to wreak havoc on your traction control as it will always be thinking one set of wheels is spinning faster/slower than the other set.
Offline Brazen17
« Reply #21 on: October 01, 2012, 12:17:19 PM »
I always turn mine off so no issue for me! However...if I had to drive in the rain it might then become an issue. That's the only time I leave TC on.
« Reply #22 on: October 01, 2012, 05:21:39 PM »
I'd mix 5x115 with 5x114.3 or 5x120 with 5x120.65, but there is no way I'd mix 5x110 with 5x112 unless using wobble nuts.
« Reply #23 on: October 01, 2012, 10:05:01 PM »
So is the general consensus that wobble nuts are safe?  Any special care or attention required?  I always use a torque wrench (no impact/torque stick) already.  Is our stock setup hub-centric or lug-centric?
« Reply #24 on: October 01, 2012, 10:43:49 PM »
I'm guessing hub, since aftermarket wheels come with a concentric ring.
