Author Topic: Cobalt big brakes  (Read 5762 times)
Cobalt big brakes
« on: September 09, 2012, 05:06:44 PM »
I've heard the cobalt front brakes work on our car.  Does anyone have any info on this?
Cobalt big brakes
« Reply #1 on: September 09, 2012, 05:23:25 PM »
The bolt spacing is the same for the mount and the rotor offset is the same. They are using the same size pistons that we use in our kit, but a larger diameter rotor which is going to bias the brakes toward the front. Looks like it will work, you would need the calipers, rotors, pads, possibly new lines as I have not confirmed the banjo bolt size is the same as the stock one, also different wheels or a very thick wheel spacer (.4") on the stock solstice rim will be needed for sure to do this.
I'd like to claim this knowledge as my own, but i just ate some apple pie.  Therefore, i must be honest. Its from DDM.
Re: Cobalt big brakes
« Reply #2 on: September 09, 2012, 06:06:47 PM »
I'd like to claim this knowledge as my own, but i just ate some apple Cherry Pie.  Therefore, i must be honest. Its from DDM.
« Reply #3 on: September 09, 2012, 06:58:13 PM »
« Reply #4 on: September 09, 2012, 11:04:38 PM »
« Reply #5 on: September 10, 2012, 10:12:43 PM »
I tried Rock Auto to create the same kit and came out quite a bit cheaper; can't remember exactly how much, about half if I wasn't mistaken.  I didn't buy the parts; just curious how they compare.
Either Autozone or O'Reilly also sells rebuilt Brembo calipers for much less than a new one.
« Reply #6 on: September 10, 2012, 10:45:23 PM »
Got links to help out other forum members?
Re: Re: Cobalt big brakes
« Reply #7 on: September 11, 2012, 08:41:37 AM »
what year and model did you use?
sent from my android phone using Tapatalk 2
Offline JoshMcMadMac
« Reply #8 on: September 11, 2012, 09:03:27 AM »
I have not seen Brembos on Rock Auto, are you sure you were not pricing out standard Cobalt calipers?
« Reply #9 on: September 11, 2012, 09:34:36 AM »
Search for ACDELCO Part # 1722484 and ACDELCO Part # 1722485 on Rock auto. It looks as though they are the Brembo units.
Offline GypsySky
« Reply #10 on: September 11, 2012, 07:12:40 PM »
I wanted to do this also. The below thread showed me that clearance between the rotor and the wheel was not possible with my aftermarket wheels without extending the tires outside of the wheel wells using spacers. I don't like that look so I went with painted stock stoppers instead.
Thought I would share:
http://www.skyroadster.com/forums/f25/brembo-brakes-ss-cobalt-34657/
« Last Edit: September 12, 2012, 04:59:14 PM by GypsySky »
« Reply #11 on: September 11, 2012, 07:38:32 PM »
Nope.
2008 or 2009 should work equally well.
« Reply #12 on: September 11, 2012, 08:16:39 PM »
Wow, those are thick.
I am not sure of those would fit with my Ultraleggera's  and no spacers
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #13 on: September 12, 2012, 12:02:19 PM »
Hmm,, someone in the Mid-Atlantic bite and we can all swing by to check clearances :)
« Reply #14 on: September 12, 2012, 12:32:41 PM »
I've 2.25" between my Ultraleggeras and the rotor on the front.
