Author Topic: Clutch Going Out?  (Read 13068 times)
Clutch Going Out?
« on: October 09, 2012, 03:40:57 PM »
What are the symptoms of the clutch getting ready to kick the bucket? Besides the car not moving!  :D Maybe I should ask what are the beginning symptoms...
Offline 1KULSOL
Re: Clutch Going Out?
« Reply #1 on: October 09, 2012, 03:46:03 PM »
here's a couple:
1) rpm's going up and mph staying same or less 2) burning smell
« Reply #2 on: October 09, 2012, 07:02:36 PM »
Usually slipage in a higher gear, when you I try to accelerate
« Reply #3 on: October 09, 2012, 10:48:39 PM »
I think both of your answers hit the nail on the head. Crap!
« Reply #4 on: October 10, 2012, 05:50:52 AM »
How many miles on your car?
« Reply #5 on: October 10, 2012, 08:36:33 AM »
65000. And I drive with a fairly heavy foot. And I might have added a Trifecta tune....   :D
« Reply #6 on: October 10, 2012, 08:54:42 AM »
Same here, must be the heat in Vegas.  I'm over 86k miles on stock clutch :knock:
« Reply #7 on: October 10, 2012, 10:18:14 AM »
Could be my shifting technique as well. I probably feather it to much.
Offline EarthNTX
« Reply #8 on: October 10, 2012, 10:28:44 AM »
What do you mean 'feather it too much' ?? I don't understand. :(
Ride it like you mean it.
« Reply #9 on: October 10, 2012, 10:38:16 AM »
I refer to it as engaging the clutch slower so as to make the shift between gears smoother. I may have ended up putting a glaze on the clutch. I've heard aggressive shifting is less stressful. Don't know if that is true or not but it kind of makes sense. Of course it would put more stress on the drivetrain...
Offline EarthNTX
« Reply #10 on: October 10, 2012, 10:41:22 AM »
Ah..NOW I get it. Thanks! Love this forum :)
« Reply #11 on: October 10, 2012, 11:58:38 AM »
Clutch lining glazing and failure comes from slippage and heat build up. Drag racing shifts will kill one pretty quick, as will allowing any slip at any other time such as shifting.  When it is fully engaged, it doesn't wear.
« Reply #12 on: October 10, 2012, 02:49:02 PM »
You have to take your foot off the clutch pedal every so often :)  :poke:
« Reply #13 on: October 11, 2012, 12:08:20 PM »
My technique could use some work...  :thumbs:
I probably did most the damage in the first few thousand miles. The last time I drove a manual was in 1985.  :gaah:
« Reply #14 on: October 11, 2012, 01:08:50 PM »
Do you stand on the clutch at stops?  In my experience that will wear out a clutch much faster then if you put it in neutral and let the clutch out.
« Reply #15 on: October 11, 2012, 01:21:59 PM »
Not all the time but I often do. I tend to fidget between holding the clutch and putting it in neutral and if it is a long redlight I might go back and forth several times. Maybe I'm borderline ADD?  That would be interesting if true. The clutch thing not the ADD...
« Reply #16 on: October 11, 2012, 01:32:35 PM »
It would wear if you don't have it 100 % disengaged.  You could have a very light contact and not even know it.
« Reply #17 on: October 11, 2012, 01:44:22 PM »
You know, sometimes when I shift between first and 2nd, such as at a stoplight, it feels like the car moves ever so slightly so you might be on to something there. It doesn't do it everytime but certainly does sometimes.
« Reply #18 on: October 11, 2012, 03:34:20 PM »
Your causing wear even if the disc is 100% disengaged however the wear will be to the pressure plate and release bearing.
« Reply #19 on: October 11, 2012, 04:35:02 PM »
Is this adjustable? If I install a higher performance clutch (or even a stock clutch) I don't want it to wear out any sooner than necessary.
« Reply #20 on: October 11, 2012, 07:45:28 PM »
nope no adjustments.  It is self adjusting hydraulic clutch
« Reply #21 on: October 11, 2012, 08:10:03 PM »
How is that? Quick shifts engage the clutch fully.  I have over 100 trips down the drag strip, daily driver and still on first clutch
« Reply #22 on: October 11, 2012, 09:24:51 PM »
Full throttle shifts allow slippage but the main wear is getting off the line.
We almost never wear out a disc in road racing.
« Reply #23 on: October 12, 2012, 10:13:27 AM »
I never had a problem in my car.  But I don't have my car anymore.  So maybe I have a problem with the car now?
« Reply #24 on: October 12, 2012, 11:09:24 AM »
Wasn't your's an auto?
