Author Topic: LED Turn Signal Project  (Read 1864 times)
« on: January 11, 2013, 07:09:59 PM »
The top white strip is linked to the running light circuit on the 3157 bulb in the bottom corner.  So now if I put the driving lights on, or the headlights on, the white strip will light up.
I turned the "corner" light with the tri-cross hair into a turn signal flasher since I no longer need it as a corner light.  And then did the quick and easy side light into a turn signal flasher.
Will eventually either tint the lower signal/running light or paint it black, and delete it.  Just playing with it for placement right now.  Pretty happy with it right now after some repositioning.
DSCN2816
Looks like the vid is working again, might've been a youtube problem.
« Last Edit: January 12, 2013, 02:49:06 AM by Carbon Sky »
