Author Topic: Waterpump replacement instructions  (Read 81217 times)
Re: Waterpump replacement instructions
« Reply #50 on: August 26, 2014, 06:23:37 PM »
I will add that changing the thermostat by itself is not fun on this car.  With having to burp it several times.  You have to pull the thermostat manifold, it's inexpensive, save your self a lot of work later and replace it.
Offline wizardofflight
« Reply #51 on: August 26, 2014, 07:29:01 PM »
Thank you, last time I had to change a water pump was on my 76 Sunbird.
I have been running the car trying to get it to leak, so far nothing. The other day I had a puddle now not even a drip.
Alan
« Reply #52 on: August 26, 2014, 07:45:04 PM »
You're on borrowed time Alan.
DDMWorks sells the pumps on their site and when you get the thermostat MAKE SURE you get an OEM ACDelco. Any other one will give you nothing but grief.
http://www.ddmworks.com/GM-OEM-Waterpump-for-20L-24L-Ecotec_p_346.html
« Reply #53 on: August 26, 2014, 10:16:50 PM »
DDMWorks is definitely where I was going to get the parts from. I saw that they have everything the pump, thermostat and the O-rings.
Thank you guys,
Alan
« Reply #54 on: August 27, 2014, 01:59:17 AM »
Also- be sure to drill a SMALL HOLE in the ring of the thermostat. Please refer to DDM for specific drilling locations. This will speed up the burping process significantly.
« Reply #55 on: August 28, 2014, 02:32:29 PM »
Yeap, just a small little bleed hole helps out tremendously when doing the bleeding on these.
« Reply #56 on: August 30, 2014, 05:59:47 PM »
Is that why some T-stats have a small hole on the ring?
« Reply #57 on: August 31, 2014, 11:22:17 AM »
Yeap, gives them a little bleed for air to come up through. It is a little tricky on the Kappa thermostat since the space is a little tight, but we have done a lot of them now. Might need to do a video on it, since everytime we drill a bleed the system will purge all of the air the first time, usually ;)
« Reply #58 on: August 31, 2014, 11:28:13 AM »
Every time , usually.
It works 50% of the time all the time.
« Reply #59 on: August 31, 2014, 01:24:04 PM »
Video video :-)
« Reply #60 on: August 31, 2014, 08:44:48 PM »
Dave, what do consider a small hole? 1/16"?
« Reply #61 on: September 03, 2014, 10:03:36 PM »
I'm not sure if this is the right thread for this but...
I'm sitting in the PHX airport with a 2.5 hour layover. I've challenged the bartender to make Rye drinks I've never had. So far I'm up 2-0
He must be an amateur. He started with a Manhattan and went to an Old Fashion. Does he think I'm a ROOKIE?
« Reply #62 on: September 04, 2014, 01:12:03 PM »
Deja Poo – the feeling that you’ve heard this shit before.
« Reply #63 on: September 05, 2014, 02:38:12 PM »
will be glad when the boos gets back and can banned him a week for every time he posted this same post
« Reply #64 on: September 05, 2014, 02:54:27 PM »
DDM Dave, you mentioned a small hole in the thermostat ring. How small is small?
« Reply #65 on: September 05, 2014, 03:38:49 PM »
How small is small?
There are so many possibilities...
When who gets back?
« Reply #66 on: September 05, 2014, 03:52:50 PM »
The boos.    :coffee:
« Reply #67 on: September 07, 2014, 11:32:05 AM »
The boos is visiting me next. So don't expect a ban unless I accidentally ban myself.
« Reply #68 on: September 07, 2014, 04:06:03 PM »
We drill a 1/16" hole
« Reply #69 on: August 16, 2015, 10:28:39 PM »
Did mine today.  It should be mentioned in the instructions that even though you drain all of the coolant out of the radiator, there is still a SIGNIFICANT amount in the system that comes streaming out when you remove the temp sensor, banjo bolt, and thermostat housing.  I swear I soaked up more antifreeze off the floor with paper towels than I caught in drain pans.
Also it sort of stings when you get dex-cool in your eyes. :(
Also, I pulled my cat as well, but not the turbo.  I was able to get the water pump out through the bottom (between turbo and frame) in two pieces... and the new one back in through the same route.
« Last Edit: August 16, 2015, 10:35:56 PM by 2kwk4u »
« Reply #70 on: August 18, 2015, 09:20:37 PM »
How many miles were on the car when the pump let go? I know I'm on borrowed time with mine.
« Reply #71 on: August 18, 2015, 11:06:01 PM »
92K miles.  The ecotec in my Saturn VUE is still on its original water pump wit 210K+ though...
« Reply #72 on: August 20, 2015, 07:52:37 PM »
I replaced Dee's at about 58K.  I'm on 60k since my last change with 107k on the car.
« Reply #73 on: August 20, 2015, 09:28:19 PM »
And you did Dee's right not like your car was done.
