Author Topic: Lowering Rear Suspension ONLY  (Read 4198 times)
Offline S.P.
« on: March 28, 2013, 08:26:42 PM »
I'd like to eventually lower the the rear to take some gap out of the rear wheel wells. Hopefully have it matched it up with the front. Don't want to lower the front because stock height is plenty low for me. Does anyone have any experience/tips to accomplish this? If not I'll probably bite the bullet and get some kappasprings.
Offline silverfox90
Re: Lowering Rear Suspension ONLY
« Reply #1 on: March 30, 2013, 01:06:02 PM »
Even if you get springs you're still going to want to lower the front because once everything settles it will not sit right. I went with B&G 1.75" drop springs and the only piece that ever scrapes is the plastic air deflector when backing out of the driveway.
2008 Solstice GXP- 31,000 miles, 5 speed: Trifecta tune, 20% tint sides, 5% rear, Windrestrictor V2, tinted tails, leather wrapped and stitched center console.
« Reply #2 on: March 30, 2013, 01:44:05 PM »
And make sure the rear springs have the proper spring rate.
Some are softer than the fronts which will allow the muffle to hit at times
« Reply #3 on: March 30, 2013, 11:00:48 PM »
GXP ZoK springs are the best set up you can find.
« Reply #4 on: March 30, 2013, 11:34:06 PM »
Critterman.  Welcome and    :rofl:  . I think you are in a deep sleep and can't wake up .   :nuts:     :slap:  wake up
« Reply #5 on: March 31, 2013, 12:24:14 PM »
That's not me
« Reply #6 on: March 31, 2013, 12:48:42 PM »
« Reply #7 on: March 31, 2013, 12:59:38 PM »
somebody should start a new sub-forum ( Who are you or who do you want to be . Now that would be fu*^&% -up for real . E.B you start it
Offline Sbutcher2
« Reply #8 on: April 01, 2013, 08:25:11 PM »
Wondering how the steering is going to be effected with lowering the rears.
In the autocrooss events with factory Bilsteins the car tends to be tight into the corner and pushes through it if there is to much speed.
Enjoying the open ride.
Offline GXP_Matt
« Reply #9 on: April 02, 2013, 09:27:51 AM »
Eh just chop a coil out of the stock springs.  Stiffer rear springs will take care of some of the stock understeer as well :)
