Author Topic: Weird coolant leak  (Read 3953 times)
Offline cdnite
Weird coolant leak
« on: April 05, 2013, 12:38:04 PM »
Has any had a coolant leak in the area I circled in the image?
It looks like maybe the seal for the coolant pipe under the turbo melted.
--Christian
Re: Weird coolant leak
« Reply #1 on: April 05, 2013, 02:04:41 PM »
Where there is a gasket, there is always a possibility for that gasket to leak.
Offline cdnite
« Reply #2 on: April 05, 2013, 03:09:05 PM »
Don't tell me what I don't want to hear!
I just put this new turbo on 14 days ago and now I have a leak under it! Damn the Engine Gods!
--Christian
« Reply #3 on: April 05, 2013, 03:24:11 PM »
I ran into the same thing with my Jeep
I installed a completely new Steering system from PSC that included a new resovoir tank, pump and hydralic pump that gets attached to the tie rod.
It's like Power steering on Steroids.
Less than 2 weeks after the install, the water pump fails
Had to remove everything that was just installed
So I completely understand your pain.
What turbo did you install?
Offline cdnite
« Reply #4 on: April 05, 2013, 04:48:43 PM »
EFR 6758, I'll post a complete thread when I have it tuned and running without leaks... DAMN... I can't even get those seals today!
I'm going to go stomp around the house for a while...
« Reply #5 on: April 05, 2013, 04:49:59 PM »
Cool, you managed to find a Unicorn.
« Reply #6 on: April 05, 2013, 05:53:50 PM »
Eleanor ?
« Reply #7 on: April 05, 2013, 09:17:40 PM »
My beater has ran fine since 2004 since I bought it but a few months ago I had to install strut bearings (not related to muffler bearings) and just installed loaded struts to save a lot of hassle.
A few weeks later I'm hearing a front wheel bearing whine as I'm driving to Toronto to pick my wheels op for the Solstice. Changed the wheel bearing a few weekends ago.
Why is it that things go in pairs like that?   :idk:
« Reply #8 on: April 05, 2013, 10:14:09 PM »
 My Dad use to say things always happen in threes . I've found that true for the most part.
Offline cdnite
« Reply #9 on: April 06, 2013, 12:18:26 AM »
The banjo fitting on the coolant supply line had a cracked weld/solder where the pipe meets the round fitting.
I replaced it and all is well now. Thanks for the help guys!
--Christian
« Reply #10 on: April 06, 2013, 04:02:20 AM »
He says with tonge planted firmly in his cheek.   :D
