Author Topic: Part Numbers  (Read 2939 times)
Offline Brazen17
Part Numbers
« on: April 05, 2013, 08:29:42 PM »
Where is the best place to find oem part numbers for our cars? Specifically the clutch, master cyclinder, slave cylinder, and throw out bearing. Did I miss anything else needed to do a clutch change?
Or does anyone have a good source for the above items at better than dealer price?
Re: Part Numbers
« Reply #1 on: April 06, 2013, 04:09:11 AM »
You'll find a few places listed in this thread as well as http://www.crateenginedepot.com/Default.aspx who is a vendor on the forum.
http://www.kappaperformance.com/forum/index.php?topic=5717.0
Re: Part Numbers
« Reply #2 on: April 06, 2013, 04:28:43 AM »
Don't forget a pressure plate.  And possibly flywheel.
Re: Part Numbers
« Reply #3 on: April 06, 2013, 06:53:03 AM »
This site will give you actual GM part numbers and then contact CrateEngineDeport which is GMAccessories for the best prices...
http://parts.nalleygmc.com/
Offline Brazen17
Re: Part Numbers
« Reply #4 on: April 06, 2013, 10:47:39 AM »
Thanks guys! Since this is the first clutch change shouldn't I be able to get by with a resurface on the flywheel?
Offline Brazen17
Re: Part Numbers
« Reply #5 on: April 06, 2013, 11:44:19 AM »
Isn't our transmission the same one used in the Chevy Colorado?
Re: Part Numbers
« Reply #6 on: April 06, 2013, 05:06:30 PM »
in 06 it was the same tranny, but I believe they changed the gears in 07
