Like TS and DeepBlue said I used the Quick Disconnect Tool and Zip Ties here are some pictures.
Tools list:
1 -- 3/8 Quick Disconnect Tool (A/C or Fuel Line)
1 -- Small Snip or Cutter
1 -- Zip Tie to cut up (about 1" in length)
1 or 2 --Pick Tool (To cram the cut Zip Tie in to the fitting)
2 or 3 -- Human Hands in moderate to good condition
1 -- Moderately sane and patient mind
10 to 30 -- minutes of time with all the above tools and no experience (Your time frame and results may very)
Extras:
Band-aid and Nurse (Wife or Girlfriend will suffice)
Little bit of luck or skill
Use the 3/8 Quick Disconnect Tool to remove accessible the fittings by pulling on the fitting to separate it a little, then clip the tool around the pipe (male) side with the flange on the tool going in to the female side of the fitting. Now push the fitting together while firmly squeezing the tool in to the fitting. This should unlock the fitting so you can then pull off the female side, this may take a few tries to get right.
The fitting on the valve cover front and on the check valve (PCV) wont work with the 3/8 Quick Disconnect Tool. For these you will need to cut ~1" of Zip Tie (enough to rap around the inside of the fitting) pull the fitting apart some and cram the Zip Tie piece in to the female side of the fitting with the picks (careful not to poke yourself #Band-aid and Nurse). When you have the Zip Tie crammed in there good push the fitting back together, this should unlock the fitting and you can pull it apart. This is where the sanity, patience, luck, and skill come in to play... its not to difficult once you've done it, but the first time is tricky... Good Luck.
--Christian
