Author Topic: F-Prepared GXP Build  (Read 58781 times)
Offline DrJones
Re: F-Prepared GXP Build
« Reply #50 on: September 30, 2013, 01:04:55 PM »
Here's a sweet picture from Nationals by AutoxPix.com!
2007 - GXP - White
Offline SolNut
« Reply #51 on: September 30, 2013, 05:13:06 PM »
 :agree: Yes Sir!  :thumbs: :drive:
« Reply #52 on: September 30, 2013, 05:14:52 PM »
So cool!  Love that car.
« Reply #53 on: September 30, 2013, 07:06:33 PM »
And then the geek in me realizes how cool the flat black helmet looks in contrast to the white car.
It really helps make the pic.
Offline DrJones
« Reply #54 on: May 19, 2014, 11:45:25 AM »
We were having trouble with the motor mounts.
I tore the drivers side into two pieces at some point and the replacement one didn't seem like it was doing a good job. Under full acceleration from a stop the gear shift would rise up about 2"! not to mention the replacement one was a little taller than the OE one for some reason which caused an offset of the gear shift to the right a tiny bit.
So, we made our own. And surprisingly the NVH isn't that bad... relative to what it was before the new mounts ;)
And the gear shift is centered again.
Material costs: <$50
Time: ~6 to 8 hours
Tools: Bandsaw, lathe, Drill press, welder, grinder.
2007 - GXP - White
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #55 on: May 19, 2014, 08:46:02 PM »
Hello and great job, car looks cool. Thanks from Norm
« Reply #56 on: May 19, 2014, 09:17:20 PM »
Dr Jones is one if my favorite people. I've never met him, hardly ever see him post anymore. BUT-
He cut the top off his car
He drives like the stig
He crashes and tells
And he is smart enough to make his own solution to a problem.
Dr Jones- please clone yourself several times and send yourself out to conquer the world.
Sent from my iPhone using Tapatalk
« Reply #57 on: May 20, 2014, 11:05:47 AM »
You might want to get a room. :poke:
Offline DrJones
« Reply #58 on: May 20, 2014, 11:59:58 AM »
Awe thanks, You're making me blush.
And sorry, as much as I like a Jack and ginger ale. I don't think I like this Gentleman Jack like that :P
2007 - GXP - White
Offline DrJones
« Reply #59 on: May 20, 2014, 12:04:06 PM »
Thanks, Norm!
All of your fiberglass is working great!
Any plans on a stock fiberglass hood? this off brand one I got (the only fiberglass piece that isn't from Norm) will have to go at some point. It's heavy even though we removed a lot of the under structure and it still doesn't fit well even though we chopped and sectioned it a bit to help it a bit.
Eventually I think a front clip will be used on the car. Either the hood and front bumper combined or Hood/bumper/quarters. But that would require some trick front quarters.
2007 - GXP - White
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #60 on: May 20, 2014, 11:19:26 PM »
Hello, Ive always wanted to build a one piece tilt front end. It would eliminate a lot of the front tubing and complexity not to mention weight. Similar to what we build for the Fiero now. What rules can you run, can you have a upper vent to allow the hot air from the radiator go up and over the car rather than underneath, can the front tires be fully covered from the front view. Id like to incorporate the SD290 bumper into this with the top vent. The only reason I havnt done this is the roofs for the sky and Solstice have basically killed me in time and money.  Thanks Norm
This Fiero went 155mph in the Texas Mile run, oh and guess what its all electric!
another race car, with the C6 headlights
Offline DrJones
« Reply #61 on: May 11, 2016, 08:12:28 AM »
A sneak peak of the next modification...
Sent from my SM-G920V using Tapatalk
2007 - GXP - White
« Reply #62 on: May 11, 2016, 09:05:57 PM »
That's a bit excessive for a differential cooler, DrJones!
Offline DrJones
« Reply #63 on: May 15, 2016, 08:46:29 AM »
2007 - GXP - White
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #64 on: May 15, 2016, 11:24:59 AM »
WOW!
Offline DrJones
« Reply #65 on: May 16, 2016, 11:26:26 AM »
Utilizing the stock radiator mounts (upper and lower)
Planning on placing the reservoir in the back.
Still debating hose/pipe running but it's looking like we'll run one line through each frame rail.
Hopefully there is enough space outboard the frame in the rear near the bumper to relocate the electric water pump
2007 - GXP - White
« Reply #66 on: May 16, 2016, 11:45:23 AM »
How do you plan on air exiting the trunk?
Offline DrJones
« Reply #67 on: May 16, 2016, 12:16:34 PM »
Cutting out the license plate opening right behind the fan.
I'll put some sort of grate/grill over the opening.
2007 - GXP - White
Offline DrJones
« Reply #68 on: May 24, 2016, 08:58:41 AM »
Ran one of the coolant lines to the rear last night.
2007 - GXP - White
Offline DrJones
« Reply #69 on: May 26, 2016, 10:50:30 AM »
Roughed in the coolant reservoir.
2007 - GXP - White
« Reply #70 on: May 27, 2016, 01:58:33 AM »
Interesting real plumbing :) I didn't know our frame is so empty with no restriction that we can run a hose from front to back.
With so much more plumbing I suppose the water pump need to be upgraded, more flow & more pressure, right?
Offline DrJones
« Reply #71 on: August 01, 2016, 10:57:49 AM »
Still using the Davies Craig electric waterpump.
Temps are about the same as before but the drivers seat is much cooler now that we don't have as much heat under the hood.
Next project we are working on is relocating the intercooler. Should end up with shorter piping and less weight up behind the bumper.
The big push for this is the number of cracks we had been getting in the current intercooler.
We first developed cracks in the begining of 2015. Fixed them for Nationals, ended up getting a crack at Nationals and fixing it on site.
Then about a month ago I noticed the power was down and I could actually hear the boost leaking. Pulled the intercooler to find 4 long cracks along welds.
Needless to say we are going with an intercooler with cast end tanks instead of the welded plate aluminum.
« Last Edit: August 01, 2016, 12:21:29 PM by DrJones »
2007 - GXP - White
« Reply #72 on: August 01, 2016, 11:02:09 AM »
Holy cow. Looks like that IC fell from an airplane.
How did you fix in the spot? Duct tape and bubble gum?
« Reply #73 on: August 01, 2016, 11:10:07 AM »
What kind of intercooler is that?  You should never have a weld crack like that.
Offline DrJones
« Reply #74 on: August 01, 2016, 12:19:16 PM »
I'll leave the name of the company out as I had used this intercooler since 2008 without any issue. So it certainly held up great to being hit with 20 some psi over and over and over (remind you, Aluminum does not have an infinite fatigue life).
We fixed it on site with a generator and tig welder borrowed from a fellow competitor. Competitors at National autox events are the best. They want to try to beat you when you are at your best (not your worst).
2007 - GXP - White
