Author Topic: WTB: Dejon Lower Intake Pipe  (Read 3213 times)
Offline Napi
« on: May 26, 2013, 09:45:46 AM »
I'm looking for a lower intake pipe. Dejon seems to have discontinued them...
Color doesn't matter!
Looking forward to reading your offers.
Yours,
Napi.
Offline Napi
Re: WTB: Dejon Lower Intake Pipe
« Reply #1 on: May 30, 2013, 11:26:11 PM »
Still searching...
« Reply #2 on: May 30, 2013, 11:56:59 PM »
Sorry, I sold mine
But, if you broke your stock part and need a replacement, I do have a stock one
Offline Napi
« Reply #3 on: May 31, 2013, 05:02:45 PM »
Thanks, really appreciate it. But so do I. ::)
I am working on a custom pcv with an oil catch can. Therefor I need to replace the lower intake with a "closed" one, as the pcv will no longer be connected to the lower intake.
Idea is: take tue dejon part(needs to be an aluminium part...), remove the fitting, powdercoat the whole thing... ::)
« Reply #4 on: May 31, 2013, 05:18:02 PM »
You could do that with either a K&N Typhoon or a GM CAI as they are metal all the way to the turbo and connect with a single silicone coupler
Offline Napi
« Reply #5 on: May 31, 2013, 05:23:45 PM »
Due to federal regulations, I need to keep the stock airbox...
;D
Offline robssol
« Reply #6 on: June 08, 2013, 11:00:42 PM »
DDM Works makes a silicone lower intake. A little different than stock. But will work with a occ or you could cap the inlet as you suggested.
Offline Napi
« Reply #7 on: July 03, 2013, 11:34:37 PM »
Up
« Reply #8 on: July 04, 2013, 10:56:03 AM »
Up?
Moving this thread up?
Movin on up... To the East side...
Offline Napi
« Reply #9 on: July 04, 2013, 02:56:56 PM »
 :thumbs:
Offline cdnite
« Reply #10 on: July 04, 2013, 04:22:42 PM »
The Dejon lower pipe wasn't made in aluminum it was steel. I would go to a local shop and have then bend and flare some aluminum pipe for you.
You could also try to call Dave (@ Dejon Power House) and ask if he would make you one last section.
--Christian
