Author Topic: Fuel Economy  (Read 6304 times)
Offline 06CoolSolstice
Fuel Economy
« on: July 03, 2013, 02:15:59 PM »
Has anyone else experienced this?  On the way back from Nationals I was driving on the flat desert and noticed something funny.  At 60 mph my fuel economy was actually lower than if I drove about 77 mph.  77 seemed to be the optimal speed as above 80 it started to fall off.  Not being an engineer the only thing I can think of is our cars are more aerodynamic and more efficient at the higher speed than a sedan.
Garage:
2006 Solstice N/A
2001 Suburban (wife's)
1998 Trans Am
1974 Corvette Stingray
2007 Trailblazer SS (sold to by Sol)
Re: Fuel Economy
« Reply #1 on: July 03, 2013, 02:26:32 PM »
I think is more about engine, what rpms?
What was actually the difference mpg between the 2 speeds?
Small invisible declined road?
Both moments on cruise control?
Re: Fuel Economy
« Reply #2 on: July 03, 2013, 03:35:47 PM »
Aerodynamics shouldn't change with speed.  Now maybe if you were drafting behind another vehicle that might change things and if you went from a head wind to a tail wind that will improve things too.
Re: Fuel Economy
« Reply #3 on: July 03, 2013, 04:46:52 PM »
Did you use a shrink ray?
Re: Fuel Economy
« Reply #4 on: July 03, 2013, 07:31:38 PM »
Re: Fuel Economy
« Reply #5 on: July 03, 2013, 09:39:41 PM »
I  do not remember the rpm I was running at.  It was around 5am no other cars around on flat road.  I was getting 29 mpg at 80 mph, and 27 mpg at  60 mph.
Garage:
2006 Solstice N/A
1998 Trans Am
Offline ophidia31
Re: Fuel Economy
« Reply #6 on: July 04, 2013, 09:43:02 AM »
No, but the air flowing over the vehicle and where that air goes does change with speed.
I average 28mpg at 70mph when I take trips. At that speed, Im usually lugging along at a little under 3k rpm. Maybe 2800-2900rpm. At around 80mph Im up around 3100-3200rpm.
Also, our cars are far from being the poster childs of aerodynamics or fuel efficiency. For a modern 4cyl in a small car, we should be 35mpg. But since our cars are more show than flow, it suffers.
2013 Grigio Abarth 500
Re: Fuel Economy
« Reply #7 on: July 04, 2013, 10:48:48 AM »
According to my gas slips and miles driven W/cruise control on most of the time it says I averaged 27-31MPG . Most of the time I was doing around 65-80 and that was with 91 Octane until mid Ohio then 93 to MD
Re: Fuel Economy
« Reply #8 on: July 04, 2013, 10:49:07 AM »
I get 30-31 between 55-65 on my 06.
