KappaPerformance is the only forum withZERO ADS. We need support to continue this, consider premium.KP does not send emails or sell your info. Please email KappaPerformance@gmail.com for account help.
Always nice to see new stuff comming out still. But question. Does the 10% increase come from just the adjustability? Just thinking that the zok bars are 6mm wall thickness to the 4.7mm of your bars. But since the increase in size of yours over the zok bars, I would think the bars by themselves would be very similar IF the adjustability wasnt there?
Stiffness is achieved by more than just diameter and wall thickness, length, material and attachment point location also factor in. On the inner adjustment point the stiffness is 10% stiffer than the Z0K bars, the inner points are at the ZoK stiffness, you are essentially getting 2 sets of bars in one!
Do you mean the inner most are 10% stiffer than Z0K and the outer most attachment points are equal to the Z0K? So the center hole would be ~5% stiffer than the Z0K?
Will these fit on Solstice with LS3 conversion and full dual exhaust>
Do you mean the inner most are 10% stiffer than Z0K and the outer most attachment points are equal to the Z0K? So the center hole would be ~5% stiffer than the Z0K?Can I get them uncoated?--Christian
Is 11/1 your pre-buy deadline or do you have another date in mind? Or just plan on setting up the pre-buy for the first set quantity?
Also interested in the answer to this question, and why 10% adjustment? Was that just the most the stock non-adjustable endlinks allow?
I'd have preferred a 12% increase, but oh well.
What is the bushing material?I swapped out to the polyurethane bushings years ago, and LOVED the difference for autocross. Granted, I have the entire suspension set (control arms and bars) installed, but really don't want to go back to rubber and loose any of the crispness I have gained in steering.I'm very interested in these. I would then have a set of Z0K bars to sell.
The bushing material is polyurethane
Stiffness is achieved by more than just diameter and wall thickness, length, material and attachment point location also factor in. On the inner adjustment point the stiffness is 10% stiffer than the Z0K bars, the outer points are at the ZoK stiffness, you are essentially getting 2 sets of bars in one!
Ill probably buy a set. But am not going to want to pay yet as Im moving out of state shortly and am not yet sure of ky new address.
