Author Topic: P0030 and P0135 Codes  (Read 14348 times)
« on: September 21, 2013, 08:47:32 PM »
Boys and Girls - My car decided to throw 2 codes last night.  I drove it home from work with no issues.  Cleaned up the interior and a storm was rolling in so I pulled it into the garage.  The CEL came on when I started the car to pull it into the garage.  It's been on ever since.  After the storm left, I ran the car over to AutoZone and this is what I have:
P0030 - H02S Heater Control Circuit (Bank 1, Sensor 1)
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
I pulled the fuse tonight and it's not blown.
Any guesses?  Bad wiring, bad heater, bad 02 sensor??
Re: P0030 and P0135 Codes
« Reply #1 on: September 21, 2013, 09:46:48 PM »
Check the connector on the oxygen sensor between the cat and the cylinder head.  Try disconnecting it and then reconnecting, it's worth a try.  Otherwise you might have an O2 sensor that needs to be replaced.
« Reply #2 on: September 21, 2013, 10:44:07 PM »
Did anything get wet when you washed it and how was it running before you washed it ?
« Reply #3 on: September 22, 2013, 05:20:03 AM »
I didn't wash it. I knew it was going to rain and I was going to drive through the rain the next day.  I cleaned the interior and put the car away before it started raining.  The code came on before it rained. Unlikely it's water as it hadn't been in rain or gotten wet since Labor Day.
« Reply #4 on: September 22, 2013, 05:23:32 AM »
I will do. Hoping it's just come loose.
« Reply #5 on: September 22, 2013, 12:06:52 PM »
Just checked the wiring.  It looks ok.  The insulation on 1 wire coming out of the pre-cat sensor has a very small crack in it.  The connections look good.  No issues with wiring that I can see there.
The 2nd O2 sensor has a suspect wire.  It isn't broken, but the insulation is clearly broken around one of the wires.  I have pics I will try to post if I can figure out how to sync the new phone!  All other connections look good.
« Reply #6 on: September 22, 2013, 01:02:25 PM »
If the insulation is broken, it can let oxygen in and corrode the copper, which leads first to increased resistance and then a broken connection. So that could be your problem (or one of them).
« Reply #7 on: September 22, 2013, 02:00:12 PM »
Here are some photos.  Not sure if you can make it out on this link, but the white wire has a small crack in the insulation.  Very small though and may not even go through:
Another look at Sensor 1
Sensor 2 - The insulation for the wire on the left is completely cracked/broken.  However, this one isn't throwing the code.  I still wonder if it's contributing though?
« Reply #8 on: September 22, 2013, 05:02:07 PM »
I would undo the gray connector with the light blue cap and check to make sure the male and female ends have not slip down on either end.
« Reply #9 on: September 22, 2013, 07:42:01 PM »
I will try that!  Thanks!
« Reply #10 on: September 25, 2013, 08:49:21 AM »
The good doctor is thinking bad o2 sensor.  I'm gonna start there and see if that's the fix!
Offline Wartie
« Reply #11 on: September 25, 2013, 05:47:42 PM »
I should have an opening on Monday or Wednesday of next week if it can wait that long.  :knock:  :idk:
« Reply #12 on: September 25, 2013, 07:47:24 PM »
it can.  I work until 6:30 on Weds though. And I need to order the sensor.
« Reply #13 on: September 25, 2013, 08:43:08 PM »
What kind of beer do you have Wartie or should Ihawk bring some?
« Reply #14 on: September 25, 2013, 09:09:05 PM »
He has a nice selection in the garage fridge, but I should bring something to help him restock!
Offline Wartie
« Reply #15 on: September 30, 2013, 06:21:26 AM »
Guess I better hide the Wisconsin beer I just bought before we work on the car.  :devil:
Di, it can be Thursday night if that is better!!!!
« Reply #16 on: September 30, 2013, 11:13:00 AM »
Doesn't matter to me.  Thursday is a 5 am day, Wednesday is a 6:30 pm day.  Doesn't matter to me.  I just need to run home and let the dogs out quick at some point during either day.
Provided the sensor gets here!  Oh wait...says it should be waiting for me tonight when I get home!!
Offline Wartie
« Reply #17 on: September 30, 2013, 11:20:15 AM »
Thursday will be better for me!!
« Reply #18 on: September 30, 2013, 12:13:37 PM »
Thursday is fine!  Cause I'm outta here for the weekend on Friday!
Oooh this week is gonna be a busy beer drinking week! :)
« Reply #19 on: September 30, 2013, 01:19:57 PM »
Good cause if you did it on Wednesday we know what day that is right?
« Reply #20 on: September 30, 2013, 05:24:49 PM »
Mmmm beer
« Reply #21 on: September 30, 2013, 05:31:35 PM »
That is animal cruelty SA, I should report you
« Reply #22 on: September 30, 2013, 05:40:22 PM »
HUUUUMP DAAAAAAAAAYYYY!!!!!!
« Reply #23 on: September 30, 2013, 05:42:02 PM »
Now that I can see the pic... :barf:
« Reply #24 on: September 30, 2013, 10:16:20 PM »
Hey I didn't make that picture, see Kenny it is make not take.
