Author Topic: Caliper Clearance?  (Read 16218 times)
Re: Caliper Clearance?
« Reply #25 on: October 07, 2013, 10:42:38 PM »
The caliper body moves inboard as the pads wears to compensate for wear on the outboard pad, the piston takes up wear on the inboard pad.
concur
If the caliper can't move then how would the outside pad be able to move outboard any more then where it starts at with a new pad?  I think you might be overthinking this one.
Concur again... but overthinking things is my style.  Especially when I'm in a position where I can't just walk out in the garage to check things out on my own car.   :( :gaah:
Thanks again for all the help.
« Reply #26 on: October 13, 2013, 01:58:58 AM »
So the front brake calipers are larger (big surprise right) thus the clearances are less.
Minimum clearance from the caliper to the wheel is about 1/4"
[attach=1]
The distance from the hub face the wheel bolts to out to the caliper is about 3/4", the hub face is inset from the caliper.
[attach=2]
The brakes have about 4500 miles on them so they are practically new.  I didn't measure the rear brakes because the front ones will be the critical dimensions but if you need them let me know.
Anyone got some stock wheels laying around already dismounted that they can throw a square on and take a measurement like SA has done here.  Need the distance from the mounting pad to the inside of the spoke.  According to SA's measurements, that should be right about 1".  Can anyone confirm?
I'm going to look at the wheels here tomorrow.  Still not sure I want to get the 18"x9.5" ET38 and mill the mounting pads (if there's room) or if I should play it safer and get 18x8.5 ET35 and have them widened if I decide to do so later on down the road.
« Reply #27 on: October 13, 2013, 11:34:41 AM »
If they are that cheap- why not by two sets and just sell one later?
« Reply #28 on: October 13, 2013, 11:47:50 AM »
The spokes are not parallel to the flange so that dimension will change depending on the diameter it's measured at.
« Reply #29 on: October 13, 2013, 12:33:12 PM »
Tried that angle... can't sell it to CINC House.
« Reply #30 on: October 13, 2013, 12:33:54 PM »
Most critically, I'd be looking for that dimension at the diameter where the stock caliper protrudes most :)
