Author Topic: Limp mode strikes....*Problem Found-Wastegate Died* (Well...maybe not...)  (Read 28892 times)
Offline Kenny
Re: Limp mode strikes....*Problem Found-Wastegate Died*
« Reply #50 on: May 15, 2010, 06:55:38 AM »
Try to keep the old turbo if they will let you. Could have some fun with it.
« Reply #51 on: May 15, 2010, 11:41:09 AM »
Yeah, I could build that jet engine I've been planning...
I doubt they'd let me keep it, but I guess there's no harm in asking. My guess is GM will want it back to analyze what went wrong.
2012 Chevy Camaro 2SS RS LS3 TR6060
2018 Dodge Charger Daytona 392 HEMI
1998 Ford Mustang - Getting a transplant as soon as something major breaks
« Reply #52 on: May 15, 2010, 01:37:49 PM »
Do NOT hold your breath about keeping the dead turbo.  ;)
Offline scanner
« Reply #53 on: May 15, 2010, 11:23:01 PM »
Yeah, they'll want it back. Some think they can tell why it died. Some think you killed it and can tell why. Yet some will think it's alive and still hungry and call it NTF. All doubtful, the best test bench is a vehicle, which it will likely never see again. Scanner
Scanner
« Reply #54 on: May 20, 2010, 03:38:18 PM »
Update:
Still waiting on parts, eveidently a few were backordered. All have now shipped, and they're expecting the last ones to be in tomorrow.
Also, can a Moderator move this to problems and service? Ended up not being a tune related problem.
Offline Duck1313
    • Facebook
« Reply #55 on: May 20, 2010, 03:49:53 PM »
U238, what kind of issues you have? Since the race tune I have been having issues.
« Reply #56 on: May 20, 2010, 04:42:17 PM »
Just out of curiosity, had you ever tweaked/adjusted the wastegate rod?  (in other words, should I back mine down to stock? :) )
« Reply #57 on: May 20, 2010, 05:03:46 PM »
Nope, never touched it. Heck, I never even went looking to the wastegate rod, I couldn't even tell you were it is offhand.
« Reply #58 on: May 21, 2010, 01:19:01 AM »
Duck,
What are you dealing with?  You are not alone...
« Reply #59 on: May 21, 2010, 02:04:09 AM »
Done...
Glad you got it diagnosed if not yet repaired.
Offline Duck1313
    • Facebook
« Reply #60 on: May 21, 2010, 06:59:51 AM »
Race tune added to the GMPP tune (3 bar sensors). I added solo exhaust with hi flow cat, DDM charge tubes and K&N filter. If I get into it too quickly from lower RPM's it goes to 25psi and 9 times out of 10 starts knocking. Feels like it's not restricting the boost at all. Lyndon said to check the mass air flow sensor but it's clean.
Any ideas?
Duck,
Offline Kenny
« Reply #61 on: May 21, 2010, 07:01:43 AM »
how low of RPM. if you lug the engine, it'll knock. also how much knock we talking. 3* KR is not a big deal. 8* is bad
Offline Kenny
« Reply #62 on: May 21, 2010, 07:08:12 AM »
Duck, i think you should start a new thread with your issues. I think you might have the same problems as me with limp mode. but i don't wanna pollute this thread.
« Reply #63 on: May 24, 2010, 09:15:51 PM »
Well, the car went in for service today. They said it should be ready tomorrow, so hopefully I'll have a fully functional car again!
They gave me a really nice rental, a fully loaded Ford Fusion...actually a really nice car, and decently quick for a family sedan. I put it through it's paces on some back roads on the way home, really like it. Certainly not a rental to be ashamed of.
« Reply #64 on: May 25, 2010, 10:50:39 PM »
Got the car back today...
...and it's STILL broken. :banghead:
Boosts to 15 psi sometimes, then decides it only wants to boost to 5. At least now the problem seems to be intermittent, but an electrical gremlin, if the culprit, could be a pain to chase down. By the time I had it home it threw a CEL, don't know what the codes are yet.
« Reply #65 on: May 25, 2010, 10:54:25 PM »
That's a bummer U.  Things to check for intermittent boost are many, here is what I remember:
Clamps
Vac lines
Waste gate
Bypass valve
IC
Fuel cap (don't know why)
Evap purge valve
More
Good luck!
« Reply #66 on: May 25, 2010, 10:56:45 PM »
Evap purge valve? hmmm, I have had evap codes from time to time...
Anyway I'm done with this crap. I'll take it to the dealer, offer no ideas other than the symptoms, and see what they come up with. I'm spending way too much money on gas driving back and forth to Fredericksburg (1.5 hours) for this crap. They're treating me well, but this is getting nuts...
U 238,
The evap purge valve was on a train of messages on the big board that was referenced while I was struggling with a P0101 code.  The sensor or valve is under the engine bonnet and is an easy change I think.  You are still under warranty, so let them at it, but that may be a place to check.  I can try to find that link, but I will warn you, it's about 20 pages of info.  It took me an hour and 3 bottles of Jack to get thru it.
speed reader, slow drinker
What BG says is correct. if you have never replaced the Evap purge valve, maybe it would be a good idea to guide the technicians over there and have it replaced under warranty.
unfortunately it seems that you have to go by eliminating possible causes..
Good luck U-238
The evap valve was a problem I had recently.  Winegardner changed mine.
« Last Edit: May 26, 2010, 12:08:33 PM by DeepBlueGXP »
Bummer!!!  For my own background, this purge valve is different from the BOV and the PCV?
Yes it purges excess pressure in the gas tank, back into the engine I believe
Yes
Well, the codes were p0101 and another code, don't remember the number but it was for a "rich condition."
Dealer wants me to remove all my gauges, replace the K&N filter with a GM one, and buy a complete airbox. (I cut the resonators off the stock one, like a few people have done on here.) All he did was read the tunes, and he says that when he calls a P0101 code to learn how to troubleshoot it the first thing they'll ask if the car is stock or not, and that's why he wants me to undo all that stuff.
Lyndon sent me the diagnostic tree for P0101, and I'm thinking the MAF may have somehow been damaged way back when I cleaned it for the first time. A new one is $75, so I'm thinking I'll just buy a new one, swap it in and see what happens. Then, if that doesn't do it, I'll talk to my dealer, and either do like they say, or buy a GM CAI and do what they say. All the stuff Lyndon sent me points to the MAF, an exhaust restriction, charge pipe leak or bad ECM.
U 238, if you look up in the internet, you can find a new MAF, for less than $75. around 50 is the right price. if it is OK, i can post the link. is it OK Joe?
